My Ge washer door os locked while that door is open and will not unlock to allow the door to be closed. I have tried the unplug for 30 seconds and plug it back in. The door makes the clicking noise like it is trying to unlock or lock, but it remains locked and door locked light remains locked. Any suggestions what i can do next.
Thanks Nate |
Hi Nate,
It sounds like your control board is bad. You should have a tech. data sheet inside the bottom front behind the lower access panel that you can check too, GE doesn't provide online tech. data sheets I can post for you. If you purchase parts from our links here and you install them and it doesn't fix the problem, you have a 30 day full refund when you return them. The control board is #104 here: ![]() Here's the control board for your model: Manufacturer part number WH12X10355 is RepairClinic item number 1264503 WH12X10355Jake
is there a manufacture warrenty on this part? Is there any way for me to troubleshoot any more to make sure that this is the cause?
Yes, you have a 1 yr. warranty on your washer for parts & labor.
Your tech. data sheet should help you troubleshoot it further. Jake
| door latch broken can't open door | twz | KitchenAid | 12 | November 21st, 2007 06:30 AM |
| Kenmore 721.68280790 light, fan & turntable run with door open | GeneMc | Sears Kenmore | 2 | July 31st, 2007 04:17 PM |
| Kenmore Elite: freezer OK, food section too warm, air-damper is open. | t2d | Sears Kenmore | 10 | June 23rd, 2007 07:41 AM |
| GE JE1540WW mw fan running when door is open | kdh | GE/Hotpoint | 1 | August 29th, 2006 04:10 AM |
| Detergent Door will not open! Need wiring diagram. | Bob Swerski | GE/Hotpoint | 11 | July 10th, 2006 10:12 PM |
