Old June 20th, 2009, 10:21 AM
skaskeski is on a distinguished road
Default [FIXED] GE Model JGBP24BEW1WH gas range
Oven will not turn on. Broiler does turn on. I read several of the threads on similar model nubers and have an idea of what could be wrong and need confirmation that I measured correctly. Other threads suggested that I measure the voltage to the ignitor. There are two wires, one plugs into what I'll call the gas module under the over(in the back behind the kick panel) and the other wire has what i'll call a barrel connector. I unplugged both wires, and measured each to ground, the barrel connector had 120vac and the spade lug on the gas module had just residual voltage, arount 6 or 7 vac.
Did I measure correctly, and if so, can I assume then that my ignitor needs to be replaced?
Thank you in advance....this forum helped me in the past to fix my freezer, and it looks like it's gonna do the same for my stove too.
Old June 20th, 2009, 11:15 AM
The 2 wires that come out of your oven igniter glow bar and connect to your range, check for 120 volts there. Not to ground. If you don't have a quick disconnect from your oven igniter glow bar wires, I cut the wires(unplug your range first) then put the volt meter probes on the 2 wires that come from the range side and plug in your range and put it on bake, if you get 120 volts, then its the oven igniter glow bar thats bad.
Here's the cheapest oven/broil igniter glow bar I found for your model you can order(comes with new wire nuts to reconnect the new one):
Manufacturer's Number: WB2X9154
Old June 20th, 2009, 11:31 AM
OK, will do. On my installation, that would be between the "barrel" connector and the spade lug on the gas module. Quick and easy to get to.
I just checked it, and I do have 120vac, so I guess I need a new ignitor.
Old June 20th, 2009, 12:03 PM
Yes,
Yup, ok, the new oven igniter glow bar will fix it for ya.
Old June 20th, 2009, 01:37 PM
Thanks Jake, I'll order it from you next week.
Old June 20th, 2009, 09:20 PM
Ok, sounds good, let us know how it goes.
Old July 2nd, 2009, 03:01 PM
Wow, that was fast. Ordered the part thru your link on the 1st, got it on the 2nd. Just finished the install and the oven works like a champ again.
Thank you very much for the professional advice, help and for getting the part to me so quick.
Old July 2nd, 2009, 04:44 PM
Excellent, good job.
Old July 4th, 2009, 07:11 AM
One last thing Jake: After repairing my oven, the wife wanted me to look at our son in laws because it doesn't work either. I thought his problem was different because his broiler and oven both were not working. So, to please the wife, I went and looked. Though his oven is a kenmore and mine was GE, other than his electronic timer/control panel, the ovens are identicle right down to every screw! And his broiler wasn't working cause it had no ignitor! Based on your advice, I disconnected the ignitor and measured voltage, had the 120vac. Removed the ignitor and sure enough, someone had taken this one from the broiler and spliced it into the conectors for the oven.
Before you helped me I didn't know what to look for. So your help to me actually fixed two ovens.
Thanks again!
Scott
Old July 4th, 2009, 07:38 AM
Good job Scott.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/ge-hotpoint/15885-fixed-ge-model-jgbp24bew1wh-gas-range.html
Posted By For Type Date
GE/Hotpoint on Appliance Blog Forums | BoardReader This thread Refback September 27th, 2009 12:58 PM
Gas vs. Electric Range? Here is one more view... bobl Maytag/Magic Chef/Admiral/Jenn-Air 2 September 9th, 2008 04:00 PM
GE Self Cleaning Gas Range Model JGBP24BEW1AD shevegan GE/Hotpoint 3 September 12th, 2007 10:41 AM
GE gas range leak? GEranger GE/Hotpoint 6 September 3rd, 2007 05:28 PM
Gas Range Model kenmore 790.78739402 asaood Sears Kenmore 1 August 16th, 2007 08:33 PM
Maytag Gas Range T1 MODEL mgr5770 majorillin Maytag/Magic Chef/Admiral/Jenn-Air 3 February 27th, 2007 11:10 PM
