Model # PSS26SGRC Serial # VG422948 Over 4 years old. When I open the refrigerator, I hear a clicking noise and see blinking HRS in the display panel(no temperature display). It started happening since this morning. When it is closed, water green light is flashing and I hear a howling sound. Water/Ice dispenser is not working. But it is cold inside and have to confirm if it is holding the temperature. I see different threads of mother board issue. Is it the same one? I called GE but they have no clue about blinking HRS and asked me to schedule a technician. Any help would be appreciated. |
It sounds like the motherboard is bad. Here's the one for your model you can order: Manufacturer part number WR55X10656 is RepairClinic item number 1266104 WR55X10656If you purchase parts from our links here and you install them and it doesn't fix the problem, you have a 30 day full refund when you return them. You would need to pull your refrigerator out from the wall, its #801 here, just take the cover#803 off and you will see it(Unplug your refrigerator first): ![]() Jake
milli (June 23rd, 2009) | ||
Thanks Jake for your quick response.
Looks like it is holding the temperature inside. So does motherboard(being bad) impact ice/water dispensing system? or would it eventually break everything? I'm just wondering how much time I have to try out this new motherboard? Also how hard is it to change the motherboard? I'm very comfortable in building computers. Would I be able to do it? |
Yes, it controls the ice/water dispenser as well.
You have a 30 day FULL refund on the motherboard if you order it from the link I posted above if it doesn't fix it. Its very easy to change the motherboard, all quick connects. ![]() Jake
Thanks Jake. Is it ok to leave the refrigerator on until I replace the motherboard? Or would it cause more damage?
Its fine to leave it on till you replace the motherboard.
I see GE had a recall on these motherboards. Would you know if this one(given the model/serial #) is part of the recall?
Thanks. |
Yes,
This thread explains and has the phone# you can call GE to see if you qualify for it: http://www.applianceblog.com/mainfor...61&postcount=8 Jake
Thanks Jake. Finally it stopped working yesterday but could not wait to get it shipped from repair clinic which you suggested(or check with GE if it was covered under recall). So got it from the local store and the new control board fixed it.
I did try with old one to see if I could disconnect and put it back again before buying the new one. A couple of wires were pretty tightly hooked up to the board and they were really hard to pull out. But otherwise it is back functional now. Thanks for your help Jake. |
Good job fixing it milli.
| GE Profile Side by Side increase in noise | Gerald R Bell | GE/Hotpoint | 1 | September 17th, 2008 10:15 AM |
| Whirlpool "Gold" side by side light blinking | tbone7244 | Whirlpool | 7 | August 6th, 2007 10:15 AM |
| GE side by side ZFSB23DNDSS fan noise | Jeff N | GE/Hotpoint | 2 | June 27th, 2007 09:08 AM |
| GE Side By Side vibrating Noise | KeithyD | GE/Hotpoint | 2 | July 18th, 2006 08:14 AM |
| GE Arctica Profile Side by Side Fan Noise | claroo | GE/Hotpoint | 4 | June 3rd, 2006 09:20 AM |
