This should be an easy answer but it sure has me stumped. Our GE Monogram 48" side by side is having a freezer problem. The temp will go from minus 10 degrees up to about 38 degrees and then back down to minus 10 all within a 24 hour period. Everything is clean up top and the fridge side is working properly. Any help appreciated, thanks.
Whats the model# of your refrigerator? Its located inside the refrigerator section on the upper walls or ceiling. Its possibly your motherboard thats causing this problem. Jake
So, let me get more information, was the refrigerator running when you noticed this problem? or not running? If it was running, did you hear the fan in the freezer running? or dead silent? Jake
Jake the unit was working fine, both freezer and fridge. About three weeks ago the freezer started warming up to 38 then back down to minus 10. The freezer side is making a strange noise since this started but it's not like a fan blade hitting something. More of a soft whining noise. From my very limited knowledge, it seems like the unit stays in defrost mode longer than necessary. But, it may not even have a defrost mode. Thanks, Ted
Ok Ted,
That strange noise could be your freezer fan motor bearing that may be starting to go out. I haven't worked on many of these built-in GE refrigerators to even tell you the steps to open the back panel to check it, but it looks like its underneath this #5831 panel in your freezer: ![]() Motor - Evaporator Fan P/N: WR60X190 http://www.pcappliancerepair.com/cgi-bin/promote-detail.cgi?item=WR60X190&brand=GEH&affiliate_id=AppBlog The defrost cycle should only last for 20-30 minutes every 8 hours or so. Jake
Thanks, Jake. Anything else I should replace while I've got the freezer torn down?
That should be it.
Ted, It sounds like you checked already but make sure the condenser coil up top is vacumned cleaned...
| Fridaire Freezer problem | Pat S. | Frigidaire/Electrolux | 1 | April 23rd, 2008 11:21 PM |
| Intermittent Freezer problem on SxS | LynnBilodeau | GE/Hotpoint | 17 | December 6th, 2007 10:22 AM |
| GE Freezer -evap motor fan? | redlady4850 | GE/Hotpoint | 1 | November 10th, 2007 11:41 PM |
| Kenmore overhead freezer leaks - known problem undocumented by Sears | iwanano2 | Sears Kenmore | 3 | September 15th, 2007 11:27 AM |
| Freezer Problem!!! | deviruchi | Refrigerators & Freezers | 3 | October 6th, 2006 04:42 AM |
