Old July 7th, 2009, 04:12 PM
cgueho is on a distinguished road
Default Long Defrost
I have a Ge SxS that keeps defrosting. Changed evap. fan and defrost theremastat already. It appears the heater is staying on to long or coming in when it should'nt. Even while working on it I had the door open and the back panel open for about 15 min and then the heater kicked on for about 15 min. Could it possible be the main board or the little white sensor. Sory about the long post. Thanks Mod PSF26PGSAWS
Old July 7th, 2009, 06:52 PM
Thats weird, that defrost thermostat should turn it off, make sure your heater isn't shorting to ground.
GE frige defrost problem: heater tested 23ohm but no AC voltage on it shenjiming GE/Hotpoint 3 April 19th, 2009 08:22 AM
[FIXED] Defrost Heater not working johnnyk Amana 7 November 19th, 2008 06:14 AM
GE SxS defrost problem..Likely solved, thanks Labonte18 GE/Hotpoint 4 September 7th, 2007 12:02 PM
Help needed again for Maytag 1502ARW Katiemay Maytag/Magic Chef/Admiral/Jenn-Air 16 November 4th, 2006 09:09 PM
Ice problem Elizabeth GE/Hotpoint 7 February 2nd, 2006 03:50 PM
