Old July 14th, 2009, 09:40 AM
ehlersdb is on a distinguished road
Default GE Profile Arctica ice dispensor frosting and leaking on floor
The model # on my unit is PSS26SHPASS, and it is 6-7 years old. Last summer it began frosting severely inside the ice dispensor...had to chip it away every 5-6 days. This summer, it is frosting up again, but not as severely. However, now there is water leaked on the floor every 2-3 days.
I checked the ice dispensor chute door, and it seems to be working properly, and the seal seems ok. I am also occasionally chipping out the ice block formed in the base of the freezer evaporating basin, but it gets filled back up in 2-3 days (correlated with the leaked water on floor perhaps).
Are these problems linked? Any suggestions on how I can fix this myself without paying for a service call?
Much thanks!
Old July 14th, 2009, 03:27 PM
Your defrost drain hole/line is clogged with ice, you'll need to take the shelves out of your freezer and remove the lower back panel#213 inside your freezer, then you will see a drain trough thats clogged with ice, get a hair dryer and hot water to de-ice it.
Also run something down the drain hole, I use a evaporator cooler spider snake:
Also pour a little bleach done the drain line after your rotor it out.
Also take off your kickplate#288 under the doors, and clean your condenser coils with a vacuum or brush, that may help the with the ice not sticking in your ice bucket. Or is it frosty in the dispenser chute?
Old July 19th, 2009, 02:17 PM
It's actually frosting in the dispenser chute. Not nearly as bad as last summer, but still gets ice stuck on occasion. I checked the dispenser chute door, and it seems to be working fine. Any other thoughts on this? Some people have told me in the humid months it's something that really can't be stopped...but I find that difficult to believe, especially considering that the problem didn't exist in previous summers.
As far as the leaking, I followed your advice earlier today. As you predicted, the drain was not draining at all...but it did not appear to be frozen. I ran a snake down 20-22" before it hit something. I poured hot water down, then rooted it out with the snake for a while...some gunky, rusty stuff came floating up, and it then started draining. I then poured a couple cups of bleach down. Hopefully that will do the trick.
Your specific instructions with schematics was extremely helpful. Thanks a lot!
Old July 19th, 2009, 03:52 PM
Good job clearing your defrost drain hole/line.
For the ice issue, I always get a flashlight and shine into the ice chute from inside the freezer door, and then look on the other side where the ice comes out the front of the door and if you see light, you have an air leak in the ice chute door, or the solenoid that opens/closes it is not closing it all the way, I have a thread here with photos that shows how to access the inside ice door and solenoid:
http://www.applianceblog.com/mainfor...ad.php?p=64550
Let me know what you find.
Old July 20th, 2009, 05:05 PM
I did the light test. I can see some light come through...there's probably a 0.5-1.0mm gap in some spots around the dispenser chute door. Is it supposed to seal 100% airtight?
I'm also noticing less frost after the defrost drain repair...could the moisture trapped in the unit due to the drain clog have contributed to the dispenser frosting?
Old July 20th, 2009, 07:33 PM
Yes it should be 100% airtight.
Yes, thats certainly a good possibility.
Kenmore Coldspot 106.70872990 - ice maker leaking H20 behind fridge dork88 Sears Kenmore 11 January 28th, 2009 09:50 AM
GE Arctica - Ice Maker Fill freezing/leaking RAPierce GE/Hotpoint 13 November 12th, 2008 08:28 AM
ice maker frozen and leaking on the rear ChipsXJ Frigidaire/Electrolux 12 June 9th, 2008 04:47 PM
Amana Ice Maker Leaking rasmns Amana 6 September 5th, 2007 10:09 AM
GE Performance Profile freezer leaking and frosting at ice maker outlet bbwlp GE/Hotpoint 3 September 22nd, 2005 06:09 AM
