#11
This problem will just not go away. So after replacing the control board and module the issue still occurs. Finding a good tech is also not so easy....
More info: If I start the dishwasher and the wash cycle does not kick in, I cancel the cycle and start it over again. This works sometimes and the wash cycle will start. If this does not, I again cancel the cycle. Then remove the kickplate (bottom access panel) and disconnect the blue plug from the motor in the front of the washer that should run when the wash cycle starts, plug it back in and start the washer again. This almost always works and the wash cycle will kick in. But it will only short lived and the process start over again. On the motor where the plug plugs into, there is a white plate and black cylinder. I am not sure if maybe one of these items are going bad. Any other thoughts? |
#12
Yes, its likely the wash pump motor then thats bad.
I don't see a separate part for that white plate and black cylinder you could order, it comes with the new wash pump motor. Here's the wash pump assembly for your model: Manufacturer's Number: WD26X10015 Here's the parts diagram, #310 is your wash pump motor: ![]() Jake
LinkBack to this Thread: http://www.applianceblog.com/mainforums/ge-hotpoint/16139-profile-pdw7800-no-wash-cycle.html
| PDW7800 GE | BoardReader | This thread | Refback | September 22nd, 2009 10:00 AM | |
| Series 80 - stops mid wash cycle | LARo | Sears Kenmore | 5 | June 25th, 2009 05:04 PM |
| GE profile PDW8400J00WW Poor Wash Performance | mz756 | GE/Hotpoint | 5 | June 12th, 2009 01:34 PM |
| kenmore elite 665 wont leave wash cycle | mesora | Sears Kenmore | 1 | June 16th, 2007 09:47 PM |
| doesn't shift from wash to next cycle | davbru | GE/Hotpoint | 3 | July 7th, 2006 12:03 AM |
| GE Profile making grinding noises through wash cycle | capnunderpants | GE/Hotpoint | 8 | February 15th, 2006 11:43 PM |
