LinkBack (4) Thread Tools Search this Thread Display Modes
  4 links from elsewhere to this Post. Click to view. #1
Old September 9th, 2009, 02:49 PM
whitedfam is on a distinguished road
Default [FIXED] side by side fridge not cooling
we have a ge side by side model GSS25TGM. The freezer side stopped cooling we had water under coming out from under refridgerator. The next day fridge side stopped cooling. We pulled it out and cleaned under got dog hair and dust out. Fans working but no cold air. About 6 months ago we had an issue with freezer side found a line was frozen and thawed it out with a hair dryer and has worked since then, although we started getting water draining noise when we closed the fridge door. The fridge has been off for over 12 hours so not sure can check for frost on back coils at this point.
I've read several of the threads most talk about mother boards or defrost themostate. Any suggestions where to start
JW
Old September 9th, 2009, 07:19 PM
Hi JW,
Did you notice if the compressor in the back was running while the condenser fan next to the compressor was turning? And the freezer fan was blowing? but not cold air?
Possibly the motherboard yes.
I would need the complete model#, the model# tag should be located inside the refrigerator section on the upper walls or ceiling.
Old September 10th, 2009, 03:47 AM
model # GSS25TGMFWW Serial # HD458749
The compressor is running along with the fan. Yesterday the freezer fan seemed to be blowing. Today nothing.
Old September 10th, 2009, 09:16 AM
Ok, then yes your motherboard is bad.
Here's the motherboard for your model you can order:
Manufacturer part number WR55X10942 is RepairClinic item number 1531075
WR55X10942
You would need to pull your refrigerator out from the wall, its #801 here, It should have a metal cover, just take the cover off and you will see it(Unplug your refrigerator first):
Old September 12th, 2009, 03:20 PM
recieved new mother board today. Installed it and fridge is working perfect. Thanks
Old September 12th, 2009, 08:13 PM
Excellent JW, good job.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/ge-hotpoint/16529-fixed-side-side-fridge-not-cooling.html
Posted By For Type Date
Appliance Blog Forums | Site profile | BoardReader This thread Refback September 16th, 2009 04:54 PM
Refrigerator Not Cold on RightHealth This thread Refback September 13th, 2009 02:30 PM
Refrigerator Not Cold on RightHealth This thread Refback September 13th, 2009 05:04 AM
GE/Hotpoint on Appliance Blog Forums | BoardReader This thread Refback September 10th, 2009 12:43 PM
Samsung, side by side fridge, not cooling, freezer barely freezing.......... tcleveland Refrigerators & Freezers 1 July 13th, 2009 10:28 AM
Side by Side not cooling fridge papajoe GE/Hotpoint 3 August 31st, 2007 10:11 AM
fix action for my fridge side not cooling akeric GE/Hotpoint 3 November 21st, 2006 06:36 PM
Frigidaire side-by-side fridge side not cooling, but freezer side is Jason K Frigidaire/Electrolux 7 October 27th, 2006 07:39 PM
msd2465ge - Fridge side not cooling MarkF2 Maytag/Magic Chef/Admiral/Jenn-Air 6 August 31st, 2006 11:43 AM
