December 21st, 2011, 06:49 AM
#21
Unplugged ribbon, it has beed over 12hrs and no F7 code. So I should replace the key pannel correct.
December 21st, 2011, 08:51 AM
#22
Yes at this point you can be reasonably sure the keypad is the problem.
June 1st, 2012, 02:44 PM
#23
Oven turns itself off
I have a GE Range Model # JBP 79A-S1AA. It turns itself off, sporadically, not all the time. Sometimes it gives me the error message that the Oven door is open, but it isn't and the temperature that I set it on, is only 350º or 375º.
I have tried, going out to the garage, and shutting it off from the circuit breaker box and then turning it on again. It worked. It stayed on. But,sometimes, it still keeps going on halfway thru my cooking a chicken or roast. Can you possibly tell me what is wrong? Thanks !
Have you ever heard of GE Ovens turning on by themselves? Suspect faulty ($175) replacement OC. Any other ideas
[/QUOTE]
June 1st, 2012, 06:33 PM
#24
That model# isn't showing as good, please recheck it.
Now when it shuts off, does the clock stay at the temperature? Or does the temperature thats set just go back to the clock in the display?
June 1st, 2012, 06:56 PM
#25
Thanks, Jake for replying so quickly. I'm new at these boards, so please have patience. I rechecked the Model # and it is
J BP79A S1AA < (THAT IS A NUMBER ONE). If I set it at 375º, for instance? I may look away for a moment and the darn thing goes off! (The number disappears and the oven is off).
Ah! When I go to turn it on again? It stayed at the number I had it on. 375º. Thank you ! Elena
June 1st, 2012, 07:46 PM
#26
Ok, I found it.
Yes, the problem sounds like the Clock oven control board is bad.
Unfortunately is No Longer Available.
June 1st, 2012, 08:09 PM
#27
Wow! That's what happens when you hang on to something too long, Jake. It looks brand new, but is very old. I guess, I'll have to save up, to purchase a new one. Thanks, ever so much for replying ! And I want to take this opportunity to wish you a very Happy Father's Day! Goodnight.. Elena
June 2nd, 2012, 10:07 AM
#28
Thanks Elena.
June 2nd, 2012, 11:46 AM
#29
Thank you, for all the help you give us !
Thanks Elena.
By rlsmith in forum Ranges/Ovens
Last Post: March 16th, 2011, 12:19 PM
By laroc in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: April 2nd, 2007, 10:14 AM
By spthomas in forum Whirlpool/Roper
Last Post: September 19th, 2006, 01:05 AM
By cdownen1 in forum Sears Kenmore
Last Post: September 16th, 2006, 12:42 AM
Last Post: November 7th, 2005, 07:57 PM
