Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: GE Oven Turns ON By Itself
    GeorgeR is offline Member
    Oct 2005
    Pace, FL
    Default GE Oven Turns ON By Itself
    I have a GE Profile Performance Wall Oven Model JT910BA4BB, S/N DA6 07929Q installed 5/2000. Two months ago oven control displayed F7. Troulbleshot unit per enclosed GE's procedures- they say F7="Shorted Matrix or START Key" Checked key panel-OK. Presumed then Oven Control (OC) was bad. (Friend with similar units has had 2 Oven Control failures on same age unit) Ordered new OC (GE P/N WB27T10312) and installed by moving each wire separately from old OC to new OC. Reapplied power, set clock and all appeared good. Within 24 hours oven began beeping and showed F7. Went to oven and it was ON - with no indication on display. Oven was at 350 by oven thermometer inside. Pressed OFF/CANCEL and oven turned off. Power OFF then rechecked all connections and reinserted ribbon cable. Power ON- all good. Checked oven over next two days and it was OFF and cool. Friday afternoon checked oven and display showed oven was in Low Broil. It had turned itself on!! Oven temp was 400+!! No delayed start had been set.
    Have you ever heard of GE Ovens turning on by themselves? Suspect faulty ($175) replacement OC. Any other ideas
    Last edited by GeorgeR; October 23rd, 2005 at 06:17 AM. Reason: Modek name corrected
    No, I have never seen that happen before on the GE's. But the F7="Shorted Matrix or START Key would tell me that there is a short in the start key making it come on by itself, even though you say it checks good, could be a intermittent issue.
    Tomslick is offline Member
    Jan 2006
    WA
    Default My JRP15BW Turns on by itself
    Need some help my 24" single wall oven started erroring out shortly after I bought it. I did the whole eraser trick thing for a while and finally decided to replace the control panel. I replaced it a couple of weeks ago and now the oven turns on by itself. Any ideas. Please help. Thanks in advance.
    How old is your Oven now?
    Oct 2005
    Pace, FL
    Tom,
    I bit the bullet and had a professional troubleshoot my oven that turned itself on. I had replaced the oven control with no change in the problem. GE replaced the keypad and all is good. Per repairman, keypads were/are a problem with their ovens. If new, get it fixed in warranty. - Good luck
    Jan 2006
    WA
    Default Thanks for the quick response.
    Guys -
    Not quite sure when I got it 1998/99. Had my appliances in storage awaiting remodel of new kitchen. We had to figure out what we wanted first. Last night I shut off the breaker and this evening turned it back on. My wife used the oven with no probs - just waiting to see if the "Gremlins" turn it back on. George when you say the "keypad" are you talking about the whole unit? Is the control panel different from the keypad? Thanks for your help.
    Oct 2005
    Pace, FL
    Tom,
    The keypad and the controller are separate parts. Looking up your model the part numbers are:
    WB27T10264 CONTROL OVN (ERCIII-B)
    WB36T10542 CONTROL PANEL W/KEYPAD
    The age of your oven falls right when GE started having problems with the Control Panel/KeyPad. If you're handy and can fix things, order it and install yourself. Very easy doe Control Panel/Keypad - just some screws. Good Luck
    laughngrin is offline Member
    Sep 2006
    Texas
    Default F7 error on GE oven - Part WB27T10312
    I'm having f7 issues with my oven as well. I was intending on purchasing the replacement part WB27T10312 to see if that fixed the problem. My oven HAS NOT been heating by itself but the light has been turning on and off on its own. Did you ever solve the problem on your end? What did you wind up doing? I'm hoping to get advice back before I purchase the replacment part.
    Sep 2006
    Texas
    Sorry. I didn't read all of the entries. GeorgeR - in the end, did you need to replace both the oven control and the keypad or would just the keypad have solved the problem?
    I have a JTP18BD1BB from 2001/2002. I've cleaned the connectors with an eraser to band-aid the problem until I order the part.
    Maduro is offline Member
    Nov 2007
    madison
    Default F7 (GE model 164D4105P033)
    Interested discussion thread. I typed the GE model 164D4105P033 into a google search looking to buy the replcement part to my GE profile oven and learned that I am not the only one with this "F7" problem and haunted oven light. I have been having trouble with the oven for about a year now, and have been removing the cover to the control board to clean it mich like ya'll. This helps, but the problem always seems to return. Now that I know that this oven is the quality equivelant of a early 80's Ford Granada, I think I will just replace it with another brand. Anyone done this yet? I am looking for an oven with the same dimensions so that it will go into the existing space of this GE oven without having to make any structural modifications.
    PS...is there a product recall for this GE product?
  1. Replies: 5
    Last Post: March 16th, 2011, 12:19 PM
  2. Jenn-air wall oven doesn't close & temperature is off
    By laroc in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 2nd, 2007, 10:14 AM
  3. Error codes on built-in double oven model # RBD306PDQ14
    By spthomas in forum Whirlpool/Roper
    Last Post: September 19th, 2006, 01:05 AM
  4. gas oven turns self on!
    By cdownen1 in forum Sears Kenmore
    Last Post: September 16th, 2006, 12:42 AM
  5. Amana Oven Slow To Preheat
    By scanor in forum Amana
    Last Post: November 7th, 2005, 07:57 PM
