The belt isn't frayed or burned. I can grab the pulley on the motor and turn it with belt fairly easily. When I turn it one way it spins, the other way it agitates. I can hear what sounds like power being sent to the motor for about 3 seconds then it stops (it never turns the pulley or output shaft on the motor). Maybe the motor is shot and tripping a switch? Any help would be appreciated.
Yes, it sounds like the motor may be the problem.
Had you tryed taking the belt off the motor pulley and see if the motor runs alone in agitate and spin? Here is the motor/clutch assembly for your model: Part#WH49X10035 2 Speed motor & clutch kitJake
I watched the actuall shaft coming off the motor with a flashlight and I'm pretty sure it didn't move. But I'll check it when I remove the belt to remove the motor.
Thanks, Jeff |
Well it looks like the motor is worn out to the point where it wouldn't turn with the belt on. It turned for a few seconds with the belt off then stopped. It got pretty hot. When it did turn I could easily stop the shaft with a pliers. Looks like it's time for a new washer.
Ok, yes then its definitely your motor thats bad.
| Kenmore 417 Won't Spin or Agitate | chrissz | Sears Kenmore | 6 | November 8th, 2007 01:35 PM |
| Maytag MAVT634AWW Drains, but no spin or agitate | SoCal Dave | Maytag/Magic Chef/Admiral/Jenn-Air | 5 | July 12th, 2007 05:32 PM |
| WWSE6260B1WW will not spin or agitate | John10 | GE/Hotpoint | 10 | May 9th, 2007 09:55 AM |
| Maytag MLE2000AWW doesn't agitate or spin | BMIKE | Maytag/Magic Chef/Admiral/Jenn-Air | 1 | February 1st, 2007 11:42 PM |
| Whirlpool washer won't agitate...but will spin | steph23 | Whirlpool/KitchenAid | 1 | May 8th, 2006 04:38 PM |
