I have a hotpoint Model HSS221FMBWW side by side. We noticed that the fridge side was very warm, We have come to conclusion that it had frosted up. So we unplugged it with doors open for 24 hours. It leaked alot of water out the front from the freezer side. We have plugged it back in and now it is working fine. My question is where is the Defroster timer? Is it on the control board which is GE EBX1005G01, or is it behind the panel inside the freezer?
I know we have only did a temporary fix to the problem. Thanks for you help! |
Board asm main control - Manufacturer part number WR55X10942Normally we would ohm the defrost heater(s) and defrost thermostat first and if they check ok the mother board is replaced. If they do not check ok they are changed out before the board. jeff.
| The Following 2 Users Say Thank You to jeff1 For This Useful Post: | ||
TRBERK (October 18th, 2009) | ||
Thank You Very Much for your reply Jeff!
After further checking I believe the heater is bad. I removed the heater and noticed that the heater is black and has a black looking powder inside. I have not yet checked the heater with a meter. As I don't have one here at home. But I will get it and check it. Can you tell me what ohm the heater and the thermostat are suppose to be? Last edited by TRBERK; October 18th, 2009 at 07:14 AM.. |
If you have a multi-meter, check the resistance of the heater by disconnecting the wires from both end of the heater and, with the meter set to "OHMS", put one meter lead on each end of the heater. If you get no resistance reading, replace the heater.
Defrost thermostat will have full continuity when cold and none ( open ) when warm. jeff.
TRBERK (October 19th, 2009) | ||
Thank You Very Much Jeff! I check it today.
| Hotpoint CTX18ELG runs all day, but cools fine | hotpointfan | GE/Hotpoint | 2 | October 1st, 2007 10:07 AM |
| Hotpoint WMA9~ flashing lights | Lisa_1 | GE/Hotpoint | 3 | November 10th, 2006 10:52 PM |
| Hotpoint washer saying 'TEST' | batleyvic | GE/Hotpoint | 3 | September 4th, 2006 11:55 AM |
| How to replace timer switch on Frigidaire side by side refridgerator | Pfaffy | Frigidaire/Electrolux | 7 | June 14th, 2006 09:15 AM |
| Hotpoint Dishwasher leaks at bottom | DeeDee | GE/Hotpoint | 2 | October 3rd, 2005 11:05 AM |
