November 8th, 2009, 06:33 AM
Ice and frost buildup in GE side-by-side
I don't imagine model number is needed here, but if it is, I can provide. We have a side-by-side model in our garage that does NOT have a water line hooked up; hasn't had one in over 5 years hooked up. For some reason, ice and frost build up at the opening at the bottom of the ice tray and into the opening on the door. Does anyone know what is causing this and how to stop it? Thanks.
Jon
November 8th, 2009, 08:11 AM
A full model# is always needed!
Where is my model#, I need a part, where should I look for my model number
At the through the door dispensor? ( see how a model# would have helped )
Where exactly is the ice/frost?
November 8th, 2009, 09:16 AM
Hi Jeff,
The model # is GSS25JFMB WW. Thanks.
Jon
November 8th, 2009, 05:41 PM
An electronic controlled refrigerator
November 8th, 2009, 06:23 PM
To try and be exact, the frost is building up in the opening of the ice maker bucket where the ice drops out of it into the opening on the inside of the freezer door. Thanks.
November 8th, 2009, 09:56 PM
Make sure the flapper door in the dispensor is closing/closing properly. Try a flash light to see if there is any opening/leaks allowing room air and freezer temp air to pass back and forth....
#62.
November 9th, 2009, 07:20 AM
Jeff,
Yes, you are correct, the flapper is not closing completely. I may need to take the door apart to find our why or cover the opening somehow (tape?) on the inside of the door. Any suggestions why it may not be closing? Thanks again.
Jon
November 9th, 2009, 01:04 PM
A good reason for the frost and such.
Some take apart helps...
http://www.applianceaid.com/gethroughdoor.html
Broken plastic piece, bad solenoid, wet/frozen insulation....
By iamhere77 in forum Amana
Last Post: August 21st, 2008, 09:58 AM
By hwg in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: August 25th, 2007, 01:36 PM
By grundi in forum Sears Kenmore
Last Post: May 27th, 2007, 10:20 AM
By mountainmommy in forum GE/Hotpoint
Last Post: December 14th, 2006, 05:39 PM
By blandis in forum Refrigerators & Freezers
Last Post: June 8th, 2005, 10:50 AM
