January 3rd, 2010, 03:02 PM
GE Monogram Wall Oven Problems
I have a 6 year old GE Monogram wall oven #ZET837SB3SS with the following problems:
1. Oven door wont completely close tight. Replace hinges?
2. Convection bake function does not work. The fan comes on but no
heat. All other functions work including Bake only.
Any ideas?
January 3rd, 2010, 11:32 PM
Yes, the oven door hinges would need to be replaced:
Manufacturer part number WB10X10078 is RepairClinic item number 1550729
I haven't worked on this model before, so I'm sure what's causing the convection bake not to work properly.
I wasn't able to locate the repair manual for this either. You may need to have a GE tech. come out to repair this for you.
By spectorequipment in forum KitchenAid
Last Post: March 9th, 2012, 02:53 AM
By rlsmith in forum Ranges/Ovens
Last Post: March 16th, 2011, 12:19 PM
By hwg in forum KitchenAid
Last Post: August 4th, 2009, 03:48 PM
By msarbpd in forum Frigidaire/Tappan/Electrolux
Last Post: November 28th, 2007, 12:34 PM
By laroc in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: April 2nd, 2007, 10:14 AM
