November 12th, 2005, 01:41 PM
Dryer Squeaks
I have a GE electic dryer model# DDE7900SBLWW & it has started to make a annoying squeaking sound while drying. The drum still spins & it is still drying clothes.
Anyone have some ideas on what may be causing this?
Thanks in advance...
November 12th, 2005, 10:50 PM
The common noise issues i usually see on the GE's are the rear drum shaft bushing and the front drum glide pad assembly worn out.
Jeff1 has a good section on the GE's here:
http://www.applianceaid.com/ge-dryers.html
November 13th, 2005, 09:18 AM
Jake:
You are correct, that seems to be where the noise is coming from. I did spray some WD40 on that area & it went away for a few loads, but has returned. I figured it would, but at least I found the problem.
Thanks for your reply!!
November 13th, 2005, 11:51 AM
Glad you found the problem,
Thanks for the update,
By fixerdoug in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: May 29th, 2007, 10:00 AM
By FRANK RIZZO in forum Frigidaire/Electrolux
Last Post: March 6th, 2007, 11:01 AM
Last Post: August 19th, 2005, 09:48 PM
By jcoon in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: August 17th, 2005, 06:06 PM
