November 17th, 2005, 05:49 AM
GE Electrice Range - cannot control oven temperature
I have a GE Electric Range that had the lower oven heating element fail, (it melted in one spot.). I have replaced the element and now I cannot control the oven temperature (may be the reason the lower element melted). The elements are full on in bake or broil respectively no matter where the thermostat is set. Since a thermostat is pretty expensive, $175-$225, I would like to find out how to make sure the unit is faulty.
The range is a JB450G and I have attempted to check the thermostat with an ohm meter and I believe that it is shorted. The only problem is that I do not have a service manual and am not sure that I am testing the correct terminals on the unit.
If anyone can help please let me know.
Alan
November 17th, 2005, 10:22 AM
How old is this range?
When the oven is on, only the bake element should be working(red hot).
Some of the older GE's used to use both the broil and bake elements just to preheat the oven when you first turned it on, but after that first preheat, only the lower bake element should only be on.
That model# is only part of it, there should be some numbers after that like: JB450G*J2
November 17th, 2005, 10:45 AM
I am not sure how old the oven is. The house is like 30 years old but the kitchen was remodeled before we moved in. So I would guess it is 12-15 years old. The model is JB450G*J2 like you said.
If I turn it to bake the lower element glows red and I cannot control the temperature with the thermostat. If I turn it to broil the same thing happens for the upper element.
Alan
November 17th, 2005, 11:11 AM
Ok, then that means your thermostat is bad, i looked up that model# and it said the digital clock/thermostat was no longer available.
Is yours the digital clock/thermostat?
November 17th, 2005, 11:18 AM
First thanks for the help. No it does not have a digital thermostat. I looked it up last night and it looks like this one: http://www.pcappliancerepair.com/cgi...5320&brand=GEH
Not sure if it is the exact replacement but it looks like it.
Thanks again,
Alan
November 17th, 2005, 11:30 AM
Yea, i looked it up again at RepairClinic.com and that looks right.
By pegleri in forum Sears Kenmore
Last Post: May 3rd, 2007, 03:27 PM
By laroc in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: April 2nd, 2007, 10:14 AM
By Nancy Reynolds in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: January 5th, 2006, 10:55 AM
By zlbrooks in forum GE/Hotpoint
Last Post: December 5th, 2005, 11:26 AM
Last Post: November 7th, 2005, 07:57 PM
