Results 1 to 4 of 4
Thread: GE Profile Model 26 Drain Tube
    jeff8428 is offline Member
    Jul 2010
    usa
    Default GE Profile Model 26 Drain Tube
    Model Number: pfsf6pkwabb
    Brand: GE
    I have a GE Profile Model 26 Bottom Freezer. It is leaking water, seems like the drain tube is stopped up. According to GE website you have to call a repairman to fix this. Is this true? Anyone have answers on how to do this and is it that hard.
    Appreciate any help you can give me
    This is a newer GE I'm not familiar with, but basically all are the same when it comes to defrost drain water.
    You would need to take everything out of the freezer, then remove the back panel assembly#36 here, then the defrost drain trough is #29 thats underneath the evaporator coil#27:
    http://c.searspartsdirect.com/lis_pn...4040-00003.png
    Then get a hair dryer and hot water to melt the ice thats likely clogging the defrost drain hole thats in the bottom middle of the drain trough.
    Then run something down the drain hole.
    Jul 2010
    usa
    Is it the same for a refrigerator with a bottom freezer. I read those were a lot harder
    Yes, same.
    Yes, from the diagram on yours and it looked more difficult to take off, due to more stuff thats attached to it. So if you don't feel confident in doing it yourself, by all means call GE to come out and do it.
  1. Maytag MDB6600AWW Won't Drain
    By cyboc in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 7th, 2010, 07:51 AM
  2. GE Profile Customstyle PTC22MBM frozen drain
    By Ketch in forum GE/Hotpoint
    Last Post: February 24th, 2010, 07:02 PM
  3. Replies: 9
    Last Post: January 29th, 2010, 10:21 AM
  4. Model KUDS01DL won't drain
    By kevinmmcd in forum KitchenAid
    Last Post: May 9th, 2008, 11:10 PM
  5. Maytag Model A9400 no Spin or drain
    By theripster in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 7th, 2008, 02:07 PM
