July 27th, 2010, 11:19 PM
Oven turns itself off?
I have a Wall unit convection oven GE profile JTP18W0A2WW. It will suddenly turn itself off in the middle of baking. When this happens the display goes blank. If you push a button on the control panel the clock will start blinking and display a time. It will blink, however the clock will be slow in relation to when the oven shut down. Also, the oven will restart if you prompt it to, but the temp will be higher than programmed to operate. I have not noticed these symptoms occur unless the temp is set over 400 degrees. No error codes. Any ideas?
July 28th, 2010, 10:09 AM
It sounds like your clock/oven control board is bad.
Here's the clock/oven control board for your model you can order here:
Manufacturer part number WB27T10219 is RepairClinic item number 875261
July 28th, 2010, 07:48 PM
Thank You. How difficult is it to R&R? Does it come with instructions?
July 28th, 2010, 11:47 PM
Yes, it should come with instructions. Just turn the breaker off to your oven first.
There should be a few screws under the front control panel to access it.
Its #16 here:
By AuKen in forum Whirlpool/Roper
Last Post: July 27th, 2010, 04:22 PM
By crawdad77 in forum Whirlpool/Roper
Last Post: October 16th, 2009, 09:32 PM
By wking in forum Ranges/Ovens
Last Post: March 30th, 2009, 04:08 AM
By tshurd in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: March 12th, 2008, 10:26 AM
By cdownen1 in forum Sears Kenmore
Last Post: September 16th, 2006, 12:42 AM
