Results 1 to 10 of 10
Thread: [FIXED] Door Latch Wiring Help Needed
    dalangi is offline Member
    Sep 2010
    NEW YORK
    Default [FIXED] Door Latch Wiring Help Needed
    Model Number: GSS1800Z01
    Brand: GE
    Hi All. I have a GE Dishwasher GSS1800Z01 18 inch built in dishwasher that the door latch broke. I bought a replacement latch and when I removed the old door latch, I was not careful enough to mark the wires that I removed. So now I have two black wires and two white wires, and have no idea which wire goes where into the new latch. Can anyone help? I would appreciate it!
    Unfortunately GE doesn't make wiring diagrams available online.
    So you would need to locate yours, its either in the console or down at the very bottom behind the lower access panel.
    Sep 2010
    NEW YORK
    thanks for your info Jake.
    In fact I contacted GE and they did email me a diagram..but it doesnt really help me, being an untrained eye. I have attached the PDF file to see if you can make sense out of it. I would really appreciate any info. Again right now I have two black wires and two white wires and not sure which prongs they go into.
    Attached Files Attached Files
    Good diagram.
    Ok, easy.
    The 2 white ones go on the right side door switch, the 2 black ones goes on the left side door switch.
    Sep 2010
    NEW YORK
    Thanks so much! I'm gonna try it either tomorrow or next day and let you know how I made out! One more question...my old switch says its 20 amp and this new switch says its 15 amp..I have been told its the correct switch from the company I purchased from..does the amp difference indicate its the wrong switch? I just dont want to blow anything out. Thanks for all your help!
    Angela
    Your welcome Angela,
    Here's the door latch switch assembly for your model:
    Manufacturer part number WD13X10052 is RepairClinic item number 1469030
    Is this the part# you ordered?
    Sep 2010
    NEW YORK
    Yes thats the switch I bought. But that switch is 15 amp..my existing switch was 20 amp. What are your thoughts?
    Thats fine, no problem with the amp difference.
    Sep 2010
    NEW YORK
    hey, i wired it as you suggested and works like a charm now! Thanks for all your help!
    Excellent, good job.
  1. GE Spacemaker Wiring Diagram Needed
    By jdconnel in forum Antique and Retro Appliance Chat
    Last Post: July 20th, 2010, 06:19 PM
  2. Wiring Diagram Needed
    By NOCLUE82 in forum KitchenAid
    Last Post: June 23rd, 2010, 06:49 PM
  3. [FIXED] Washing Machine Motor Upgrade Wiring
    By billyjoe46 in forum GE/Hotpoint
    Last Post: October 16th, 2008, 09:00 PM
  4. Detergent Door will not open! Need wiring diagram.
    By Bob Swerski in forum GE/Hotpoint
    Last Post: July 10th, 2006, 11:12 PM
  5. wiring diagrahm needed for control panel
    By lwhfuture in forum Sears Kenmore
    Last Post: February 13th, 2006, 01:12 PM
