Results 1 to 3 of 3
Thread: Display Dead, No Power After Start
    freezimmerman is offline Premium Member
    Sep 2010
    Alexandria, VA
    Default Display Dead, No Power After Start
    Model Number: JVM1350BW-02
    Brand: GE
    My microwave died mid-cycle (after about 30 seconds of heating a drink). No strange noises, just cut out and the display panel was blank and non-responsive.
    I took off the panel to see if something was fried back there. I saw a ceramic fuse so I thought I'd give that a shot. Replaced it with another 250V 20A fuse and the display came right back on good as new after plugging it back in. Reset the time, went through most of the non-cooking functions (set the clock, turned on the surface light, timer, etc.) and they all seemed to work fine. Thought the problem was fixed.
    However, when I attempted to use it to heat something this morning, it allowed me to enter the time without a problem but died about one to two seconds after hitting the "Start" button. Display panel dead again.
    So I'm assuming the blown fuse was not the problem but the machine's resolution (or at least safety) for the problem. Anyone know what the actual problem causing these fuses to blow might be?
    jackofalltrades is offline Appliance Tech
    Aug 2006
    NY
    you have a short most likely in the high voltage sector (transformer. Capacitor, Magnatron or diode). Most common are shorted capacitors and diodes. Search past posts , this problem has been addressed many times in here
    Oct 2004
    Hi all,
    Shorted capacitor is more likely since that will blow the fuse, a shorted diode normally will not.
    Microwave parts how to test capacitors, switches, magnetrons high voltage diodes
    Testing a capacitor
    http://www.applianceaid.com/
    NEW Appliance Repair Aid
    http://www.jrappliance.ca
    JRAppliance
  1. Replies: 7
    Last Post: November 30th, 2012, 05:49 PM
  2. [FIXED] DW has power; no LEDs lit; won't start (except once)
    By camaditz in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 14th, 2010, 06:01 PM
  3. [FIXED] Kenmore Coldspot SxS Dead After Power Blackout
    By jcoates in forum Sears Kenmore
    Last Post: August 14th, 2010, 09:54 PM
  4. GE Front Load won't complete cycle(s)
    By prostuff1 in forum GE/Hotpoint
    Last Post: July 14th, 2010, 04:39 PM
  5. JennAir dead display
    By dougmc in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 13th, 2007, 11:04 PM
Tags for this Thread
