Results 1 to 5 of 5
Thread: ice freeze's into chunk from ice maker
    maxdog is offline Member
    Dec 2010
    spotsylvania va
    Default ice freeze's into chunk from ice maker
    Model Number: PSS26MGTCWW
    Brand: GE
    The ice in the inc maker becomes one big chunk and there is frost in the freezer section
    Dec 2010
    spotsylvania va
    any Idea's anyone
    Read this thread about the ice maker chunk:
    Ice Maker water level adjustment
    Now frost is everywhere in the freezer? not just the back panel?
    Dec 2010
    spotsylvania va
    yes there is frost everywhere,, I checked the evaporator coils, there is no ice buildup. the defrost heater works and the evaporator fan motor runs. I ohmed out the thermistor on the evaporator motor, was 20-23 ohms at 20-30 degrees and changes with temp change. Freezer section was at 50+ degrees at 9 pm last night. just checked is at 6 degrees 3:30 am. I will make the adjustment for the ice cubes but, I think the main controler PC board is defective, YES/ NO??? The ice cubes are melting then freezing again.
    Yes, then its likely the motherboard is bad.
    Here's the motherboard for your model you can order here:
    Manufacturer part number WR55X10942 is RepairClinic item number 1531075
    WR55X10942
  1. Replies: 10
    Last Post: July 16th, 2009, 07:17 PM
  2. Ice Maker 106.2198597 Overflow
    By agodwin in forum Sears Kenmore
    Last Post: May 5th, 2009, 03:09 PM
  3. Superba Ice Maker and Water Dispener
    By Jake in forum KitchenAid
  4. Complete Ice Maker Assembly - For In-Door Ice Models
    Last Post: April 28th, 2008, 11:56 PM
  5. Ice Maker Not Working: KitcheAid Superba
    By Hookem in forum KitchenAid
