December 30th, 2005, 09:01 AM
GE Dishwasher drain problem
I have an older GE dishwasher (model GSD1200T02) that has drain problems. After it fills and goes through the first prewash cycle, the water drains fine. Then when it starts to fill for the next cycle, the water continues to drain so that when the filling is "complete", there is no water in the dishwasher. The same thing will happen for the wash cycles and rinse cycles. Occasionally, it will work fine, i.e. fill normally and not drain while filling. After observing this for awhile, I found that if I moved the on/off lever to off and then back to on while the washer was filling, the washer would fill normally without draining during the fill. However, I have to do this at each of the filling cycles. This gets a bit tedious since I have to babysit the dishwasher to get it to work. Any ideas on what I need to fix?
December 30th, 2005, 12:02 PM
Sounds like something is jamming the drain flapper open or the lingage..or the timer is feeding voltage to the drain coil at all times. Next time it does this pull the wires off of the draincoil to see if it will close...so you can see if it is mechanical or electrical...
May 11th, 2006, 09:29 AM
Me, too!
I am currently struggling with this same problem. How did you resolve the issue? I have done the following: With cycle not in process, the drain solenoid plunger moves up/down freely and the drain flapper moves freely. After that I figured it was a timer issue. Bought it, installed it, didn't fix the issue. After further investigation, I've confirmed again that the solenoid is powered correctly, pulling the plunger down, thus opening the flapper. What I observed last night is that the coil is powered (confirmed by it feeling it's downward force) for several seconds then actually is turned off (plunger now freely moves up/down). However, after the solenoid is de-energized, the flapper stays open! What is holding it open now? I reached in and could not manually move it. Meanwhile, the pump is running, and eventually the fill valve opens to bring in the next cycle's water only to be pumped out immediately!
At the back of the washer is a screen covering a check valve. I believe this is called the drain check valve. Is this correct? How does it work? When the drain flapper is opened the pump discharge appears to go back to this device. The check valve looks like it would "check" and keep the drain water from going up through the screen and back into the tub. Is this correct? Could this check vavle not functioning correctly cause back pressure to keep the drain flapper open even when the solenoid is deenergized?
Please HELP
May 15th, 2006, 04:28 AM
Fixed it!
Repair or replace your Drain Checkvalve. I did this and it fixed my problem. In the back of the tank, remove the filter screen (only 4 screws). You'll see the check valve. It's threaded in and is easily removed. Mine was gunked up with soap residue which didn't allow it to "check" freely. After cleaning and replacing, I noticed that during the drain cycle the volume of water entering my disposal has increased and that the drain time is decreased (makes sense). What still isn't clear to me is how the check valve was causing some back pressure on the drain valve that would not allow it to return under its spring force.
Hope this helps somebody else before spending $60 on a timer and/or $30 on a drain solenoid kit.
Good Luck!
May 15th, 2006, 10:45 PM
Sorry I wasn't able to get to your post in time, but thanks for coming back to inform us about your fix.
May 16th, 2006, 10:28 PM
That piston and nut assembly back there is one of the most common failures/ repairs I do on these. oh, and the motor and pump assembly.
By rickm in forum Whirlpool
Last Post: October 3rd, 2011, 04:14 PM
By shrimpsiumai in forum GE/Hotpoint
Last Post: June 9th, 2007, 09:59 AM
By Chailena in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: April 21st, 2007, 12:34 PM
By GCEvans in forum Frigidaire/Electrolux
Last Post: April 19th, 2007, 04:14 AM
By jlanhlan in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: July 19th, 2005, 06:31 PM
