hi,
i have a GE side by side frig model TFX22ZPBBWW. the problem is when i use the water dispenser the ice maker overfills and leaks. the ice maker is level. i just bought a brand new ice maker WR30X0327 to replace the problem i had with the ice maker leaking when making ice. maybe that was a mistake because i put in the old ice maker and it too was overfilling and leaking when i used the water dispenser. so i suspect the problem isn't with the ice maker unless the new one has the same problem but, at least the new ice maker isn't leaking when making ice anymore. now i would like to fix the water dispenser/ice maker problem. the one thing i noticed both ice makers doing and i'm not sure if this is by design but when i press the water dispenser the water enters the ice maker the same way it does as if it was making ice! ie through the tube above the ice maker dropping into the top of the ice maker. the ice maker overfills and leaks but, i'm also getting water from the water dispenser. just wanted to give you and update. i purchased a new relay harness and installed it today. but, water still comes out from the water line that goes to the ice maker when i request water from the water dispenser. what should i do now?? i appreciate any help you can offer. mark |
The first thread you started on this has been replied to here:
GE icemaker overfilling when using water dispenser I'm closing this thread to avoid double posts. Jake
| MSD2454GRW Icemaker stopped AND water dispenser sticks ! | bisk | Maytag/Magic Chef/Admiral/Jenn-Air | 6 | October 16th, 2007 11:50 AM |
| Water Dispenser SDX26VL | jxp_app | Amana | 6 | February 8th, 2007 11:49 AM |
| Kenmore refrigerator water dispenser drips | Mike C | Sears Kenmore | 23 | February 6th, 2007 09:57 PM |
| Frigidaire SxS water dispenser is dripping water | batman | Frigidaire/Electrolux | 2 | June 13th, 2006 12:15 PM |
| GE icemaker overfilling when using water dispenser | mark o | GE/Hotpoint | 9 | January 2nd, 2006 10:22 AM |
