Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 67
Like Tree4Likes
Thread: [FIXED] GE Profile Oven F7 error messages!
  1. #31
    G.B. is offline Member
    Apr 2007
    MA
    Default JTP56CODICC - GE Porfile Double Wall Oven - Error(F7)
    I too have been shot in the foot once again by the shotty designs of the appliance
    companies. I have already had issues with my Sharp microwave display and my Kitchenaid
    dishwasher control module. This oven issue has been an issue for me for better than a
    year now. I have been removing the ribbon cable to clean and re-set it then cycle the
    power. This usually fixes the problem for a few weeks or a even few months. I too am a EE
    but have had limited time to spend on it and did not purchase the control board or the
    module since I am not convinced it is a permanent fix. I also wounder if the panel
    sitting above the door has something to do with the failures. I have been asking my wife
    use the lower oven to reduce the heating effects on the panel and module. I'd like to
    know your fix if you could be kind enough to share it.
  2. #32
    Powerman is offline Member
    Aug 2006
    Missouri
    Default Solution for the dreaded F7 error message
    You can find my solution to the dreaded F7 error message problem at the following link:
    http://www.applianceblog.com/manual/...F7_Problem.pdf
    I have shared my fix with over 1800 folks and most report success. I hope that it works for you too. Please let me know at the following link:
    hutchipop@yahoo.com
    Good Luck,
    Powerman
  3. #33
    Aug 2006
    Missouri
    Default Dreaded F7 Problem Solution
    Hi Everyone,
    I have had folks say they could not open the link to my solution. Well, is my face red because I made a mistake in listing the link. Here is the correct link:
    http://www.applianceblog.com/manuals...F7_Problem.pdf
    Alternatively you can go to either of the following links:
    http://www.fixya.com/howto/h155060-dreaded_f7_error
    http://fp1.centurytel.net/Powerman/D...%20Problem.pdf
    I am happy to report that as of October 6, 2008 I have helped over 2000 unhappy GE customers who have experienced the F7 problem.
    Please let me know if my fix works for you too. You can email me at:
    hutchipop@yahoo.com
    Regards,
    Charlie Popeck, P.E.
    Consulting Engineer
  4. #34
    baz00ka is offline Premium Member
    Feb 2010
    Southern California
    Powerman: Well I was a skeptic but followed your directions. I wasn't able to insert the paper as far into "box" as I would have liked. Nonetheless, it's been working perfectly for three weeks now. My hat is off to you! Many Thanks
  5. #35
    donrb is offline Member
    May 2010
    Atlanta, GA
    Default Another satisfied fixer
    Powerman gets my "Wins The Internets" vote for the day.
    Fix worked like a charm.
    Not completely out of the woods yet, but I'm going to put the oven through a clean cycle to see what comes out on the other end. Haven't used the oven for around two months. Put off the fix even though I've known about it for six weeks. Should have done it the day I found the link. So simple!
    Seriously, took less than 10 min to complete and most of that time was spent finding and cutting down the right piece of paper.
    Thanks again. Much appreciated for sharing your knowledge.
  6. #36
    reelstuff is offline Member
    Jun 2010
    USA
    Thank you so much Powerman, the fix is in, folks, Man that just saved me over 500 bucks, the estimate from the parts replacer, to fix the problem, the Fix, worked instantly, after years, of trouble, and hundreds of dollars in repairs, from repair companies, the fix that worked, may have cost, about 20 cents, in supplies.
    We were thinking about just replacing both units, upper and lower, at a cost of over 4 thousand bucks, wow, is all I can say, God bless you Powerman, may you live long and prosper...
  7. #37
    kaoweb is offline Member
    Nov 2010
    Henderson, Nevada
    Default Thank you, Powerman!!!
    I also want to extend my thanks to Powerman. The solution works beautifully for my oven too! Before the fix, the problem is so consistent that F7 will appear persistently after I plug in the power to my oven. Now it is gone. Material cost: a slice of paper, 0 cents.
    Thank you, Powerman, again.
  8. #38
    austin_n is offline Member
    Feb 2011
    Austin
    I tried the paper trick and still got the error code. I'll unplug the cable and see if the error comes back. If it does then a new ERC may be in the works (ouch ) .
  9. #39
    Ok, keep us posted, and post your model# of your range/oven for the ERC that goes on your model.
    Feb 2011
    Austin
    My model number is the JT912B0F1BB single wall oven. It’s about 8 years old.
    This morning I awoke to the F7 error again. I pulled the cable out of the controller and re-powered the unit. The clock is flashing but so far no F7 code. Is the flashing clock an indicator the cable is unplugged?
    Ahh an update! After I hit submit the thing started to beep! Let me go read the code.... F0 now. I believe that is also a button stuck error. Looks like a controller is in my future. Anyone sell these cheap?
  1. Replies: 5
    Last Post: March 16th, 2011, 12:19 PM
  2. GE Profile Oven
    By jeff-b in forum GE/Hotpoint
    Last Post: March 9th, 2007, 10:03 AM
  3. Error codes on built-in double oven model # RBD306PDQ14
    By spthomas in forum Whirlpool/Roper
    Last Post: September 19th, 2006, 01:05 AM
  4. GE Profile wall oven on the fritz
    By 1Molla in forum GE/Hotpoint
    Last Post: April 20th, 2006, 05:31 PM
  5. GE Profile Oven pre-heat problem
    By bobg in forum GE/Hotpoint
    Last Post: January 2nd, 2006, 12:16 AM
