  1 links from elsewhere to this Post. Click to view. #11
Old December 10th, 2006, 01:31 PM
Beagle72 is on a distinguished road
Default GE Oven JKP15
My oven just started displaying an F0 error with beeping. Anyone know what the difference is in the F7 and F0 codes?
Seems everyone has the F7 code.
Old December 10th, 2006, 07:57 PM
They are basically the same.
Here is a test to find out whether its your control panel or control board:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Old December 11th, 2006, 03:51 PM
Default F0 code
I took the panel off and the ribbon cable clip was loose. Not in the socket, but the plastic clip has 2 clips on each side and it had become separated. I had tried the other things before and to no avail, but the snapping the clip back together seems to be working for now.
If it reoccurs can you buy a new ribbon cable? Doesn't seem to be on the parts list.
Old December 11th, 2006, 05:46 PM
Powerman is on a distinguished road
Hi Beagle72
If you will email me at hutchipop@yahoo.com I will send you instructions for a possible fix.
Powerman
Old December 22nd, 2006, 10:42 AM
LouCioccio is on a distinguished road
Default F7 error
I too have been getting the F7 errror off my GE Profile JKP56 double oven. I even tried the erasure on the ribbon end. It would seem to cure it; but came back. Now the lower oven want to come on. I was going to order a Keypad but started to look at the connector. The white connector for jp1 may have a bad solder joint(s). It does move ever so slightly. I was going to try to place a shim behind it but the caps are too far away. I then used scotch tape. I looped the tape around the ribbon keeping it flat and then tape the end to the top a the plastic fascia to give it tension. I noticed when I had the control hanging out I would get the error but if I applied upward and forward presure I could clear the error, set the clock and even turn the oven light on. It has been a couple of hours. I do not want to mess with it till after the holiday. I may take the control board off and apply some heat from a solder iron and remelt the solder to the connector.
Old December 22nd, 2006, 11:37 AM
Default Fix for GE oven F7 error message
Hi LouCioccio,
If you email me at hutchipop@yahoo.com with your email address, I will send you my fix for the F7 error message. In the past six months, I have had over 430 requests. No charge for this service.
Merry Christmas
Charlie Popeck
Old December 23rd, 2006, 12:33 PM
Powerman: Just post the fix here.
Old December 28th, 2006, 05:10 AM
Default F7 update
First time in a few years "No Problems" running the double oven. Earlier I told you that used scotch tape wraped around the key pad flat ribbon cable and attached to the inside fascia. It seems to work; we had no trouble using the double oven (upper and lower) and was able to use the timer and shut off the oven at the key pad. Usually I had to go to the breaker box and shut off the circuit breaker and usually waited 1 min for the caps to discharge beore turning it on. I will be back at work in the GE lab next week and will inspect the JP1 connector on both sides of the circuit board. I will update after the new year.
Ciao,
Lou Cioccio
Old June 19th, 2007, 09:19 AM
Ok folks, sorry about the delay in posting Powerman's(Charlie's) fix, but I have been swamped lately with tons of work.
Here is the link to it:
http://www.applianceblog.com/manuals/Dreaded_F7_Problem.pdf
moonman1 (November 26th, 2009)
  #20
Old July 23rd, 2007, 05:03 AM
truetemp1 is on a distinguished road
Default Thanks for posting the F7 fix
Thanks to Powerman for coming up with the "F7 fix" and Jake for posting it -- now I can tell everybody how I fixed my oven with an index card!
LinkBack to this Thread: http://www.applianceblog.com/mainforums/ge-hotpoint/2655-ge-profile-oven-f7-error-messages.html
Posted By For Type Date
MySpace.com - External Link Alert This thread Refback September 26th, 2009 03:36 AM
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
Thermador CT230 wall oven - blower starting by itself rlsmith Ranges 4 May 18th, 2007 09:23 AM
GE Profile Oven jeff-b GE/Hotpoint 1 March 9th, 2007 09:03 AM
GE Profile wall oven on the fritz 1Molla GE/Hotpoint 4 April 20th, 2006 04:31 PM
GE Profile Oven pre-heat problem bobg GE/Hotpoint 3 January 1st, 2006 11:16 PM
