Results 1 to 4 of 4
Thread: GE Profile REfrigerator Model 24-frozen drain tube
    Threethumbs is offline Member
    Oct 2011
    Grand Rapids, MI
    Default GE Profile REfrigerator Model 24-frozen drain tube
    Model Number: Model 24
    Brand: GE
    Age: More than 10 years
    There is ice building up on the floor of the freezer. We pulled out the shelves and the plastic panel covering the small drip pan. We melted all the ice in the freeze and did the hot water (and baking soda solution) with turkey baster routine. I could not be sure the tube opened up. I put the freeze back together and the unit proceeded to build up ice again on the floor of the freeze of the next weeks.
    How can I get that dang tube working again on this model?
    Run something down the drain hole, then run a little bleach down it.
    I use a evaporator cooler spider snake to run down that defrost drain hole:
    Oct 2011
    Grand Rapids, MI
    Thanks...I will give it a try and report back.....does that snakey thing have a grib for my extra thumb?
    Don't understand what your asking.
  1. GE Profile Model 26 Drain Tube
    By jeff8428 in forum GE/Hotpoint
    Last Post: July 17th, 2010, 07:04 PM
  2. GE Profile Customstyle PTC22MBM frozen drain
    By Ketch in forum GE/Hotpoint
    Last Post: February 24th, 2010, 07:02 PM
  3. Replies: 5
    Last Post: April 9th, 2008, 12:12 PM
  4. Ice maker fill tube frozen
    By wcdiv in forum Sears Kenmore
    Last Post: December 30th, 2007, 11:22 AM
  5. Ice maker fill tube frozen
    By dayleh in forum Sears Kenmore
    Last Post: July 23rd, 2007, 03:39 AM
