January 31st, 2012, 10:25 PM
Compressor overheated and now runs almost non-stop
GE
The compressor on my GE profile fridge overheated because of a factory mistake where one of the wires feeding power to the cooling fan was not seated properly in the connector. By the time I got to it, the compressor was so hot that it melted the icemaker line, and water was leaking everywhere. Now that I've fixed the problem with the cooling fan, and the compartments are cooling appropriately, I have noticed that my refrigerator rarely shuts off for the past 3 weeks. Does anyone have any opinions on if the compressor is completely fried beyond repair- do I need to buy a new fridge, or does the compressor just need more coolant or some other easy fix?
Thank you for any advice on an overheated compressor.
February 1st, 2012, 05:46 AM
Which fan are you referring to as the cooling fan? The condensor fan motor is by the compressor and the evaporator fan motor is in the freezer section. Is the compressor still running hot? Is the back cover over the compressor on or off? Are the condensor coils under the refrigerator clean so air can flow across them?
OWNER RICK'S APPLIANCE REPAIR
REFRIGERATION SPECIALIST
February 1st, 2012, 07:45 AM
Hi Rick,
Thanks for your reply. The fan that was not working, but is now fixed was the compressor fan. The compressor is warm to touch, but not hot. The coils are clean, and the back cover is off with the fridge pulled about 5 inches away from the wall- so I don't think it is an airflow problem.
February 1st, 2012, 08:42 AM
Originally Posted by
soulturkey
... and the back cover is off with the fridge pulled about 5 inches away from the wall- so I don't think it is an airflow problem.
Au contraire mon frère, the cover needs to be on to direct the air flow across the coils. Try that first and see if that's it.
February 1st, 2012, 09:55 AM
Hey, good to know, I will slap that cover back on when I get home, and hopefully have some good news to report in a couple days. Stay tuned!
February 6th, 2012, 08:29 PM
I put the cover back on and it is still running almost nonstop. What happens to the compressor when it overheats? Any chance it just needs more coolant?
February 6th, 2012, 09:19 PM
A sealed system issue can only be diagnosed by a certified tech with the proper equipment. If the compressor over heats it will usually shut down on the overload. Remove the back wall of the freezer and take a look at the coils. There should be an even coat of frost on all of them.
By adad4good in forum GE/Hotpoint
Last Post: September 2nd, 2011, 11:34 AM
By GeorgeM in forum Sears Kenmore
Last Post: July 3rd, 2011, 05:45 PM
By Driver944 in forum Amana
Last Post: November 23rd, 2010, 10:57 AM
By nadiao in forum Sears Kenmore
Last Post: June 27th, 2008, 12:07 PM
By erindye in forum Sears Kenmore
Last Post: January 25th, 2007, 10:39 PM
