Results 1 to 6 of 6
Thread: Profile / artica water dispenser leaks
    scollister is offline Member
    Jun 2012
    Burke, Va
    Default Profile / artica water dispenser leaks
    Model Number: PSC23SGPASS
    Brand: GE
    We just bought a home with the GE Profile with an Artica water dispenser.
    We appear to have a leak around the front faceplate of the unit. If a little water gets in the grooved bottom of the unit, regardless of how well you think you've gotten the water out, it will leak out and down the front of the unit. Since the unit is stainless steel, this results in constant water stains.
    Thank you.
    Attached Thumbnails Attached Thumbnails Profile / artica water dispenser leaks-img-20120617-00078.jpg   Profile / artica water dispenser leaks-fridge1.jpg   Profile / artica water dispenser leaks-fridge2.jpg   Profile / artica water dispenser leaks-img-20120617-00078.jpg   Profile / artica water dispenser leaks-fridge1.jpg
    Your missing 4 digits after the "G" at the end of your model#, click here to locate your full model#: Appliance Parts at RepairClinic. 125 Brands. 365 Day Returns.
    It looks like your getting constant drip from the water dispenser, do you see that dripping?
    That would cause the water to run down the front of the door.
    Jun 2012
    Burke, Va
    Thanks Jake.
    The full model number is
    PSC23SGPASS.
    We initially thought the leak was just when we dispensed water, but it now looks like it might be a constant drip. Any suggestions on how to repair it?
    Thanks much,
    Scott
    Thanks Scott,
    Its your water inlet valve thats not closing all the way causing this issue.
    Here's the water inlet valve for your model you can order here:
    Manufacturer Number WR57X10032
    Watch this video:
    Jun 2012
    Burke, Va
    Thank you Jake!
    Glad to help Scott.
  1. FIXED: GE Artica PSC23MGMAWW no water from dispenser
    By baringcs in forum GE/Hotpoint
    Last Post: January 28th, 2012, 12:16 PM
  2. Replies: 23
    Last Post: November 24th, 2011, 09:33 AM
  3. Replies: 5
    Last Post: August 27th, 2010, 09:17 PM
  4. Replies: 26
    Last Post: August 7th, 2009, 08:48 AM
  5. GE Artica Profile Water Dispenser Leaking
    By KevBo in forum GE/Hotpoint
    Last Post: August 6th, 2006, 09:42 AM
