Results 1 to 4 of 4
Thread: Magnetron Tube Kapoot?
    jaygreg is offline Member
    Jul 2012
    Ohio
    Default Magnetron Tube Kapoot?
    Model Number: JES1142WD04
    Brand: GE
    Symptom: Mag tube doesn't activate.
    Observations: Clock and timer work. Set timer in prep for cooking and press Start... sound of switch engaging, timer begins count-down, no light in cavity nor sound of mag tube.
    Conclusion: Probably inoperable magnetron tube. Already bought a replacement.
    Question: Did I jump the gun?
    Oct 2004
    I'd be checking the door switches!
    Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
    A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
    Magnetron Tube Kapoot?-micro-switch-wb24x10103-01391150.jpg Micro switch Manufacturer Number WB24X10103
    http://www.applianceaid.com/
    NEW Appliance Repair Aid
    http://www.jrappliance.ca
    JRAppliance
    Jul 2012
    Ohio
    Quote Originally Posted by jeff1 View Post
ID:	5968 Micro switch Manufacturer Number WB24X10103
    The clip was very helpful, Jeff. Thanks. I trust that the click I'm hearing is the switch engaging? But then... if it's clicking... it's engaging .... no? Well... a check of that switch is certainly in order in any event. Any idea of where I can find a diagram on my unit that would help me get to those switches?
    Oct 2004
    Just remove power, remove the outer cabinet shell to access...
    Not always.
    Microwave Door Switch Help | Appliance Aid
    JRAppliance
  1. Magnetron part for Sharp
    By flyingm in forum Microwaves
    Last Post: September 18th, 2011, 07:51 PM
  2. Magnetron fails again after 3 years?
    By pennstatejeff in forum GE/Hotpoint
    Last Post: March 6th, 2011, 06:42 PM
  3. O.T.R. Microwave Magnetron thermostat failure
    By Appliance Guy in forum Microwaves
    Last Post: December 13th, 2010, 08:03 PM
  4. how do you change a magnetron
    By jakeway in forum Sears Kenmore
    Last Post: November 15th, 2007, 06:13 PM
  5. model# 721-8841490 arc from backside of magnetron
    By gpriceco in forum Sears Kenmore
    Last Post: January 20th, 2007, 08:59 AM
