1Likes
January 22nd, 2013, 06:14 PM
Ge Microwave Night Light out
GE
Night Light out. I replaced Bulbs, also replaced Control Panel with another Microwave. Put in another set of Bulbs, still can't get it to light. The inside light and all other functions work fine. Just the lower night light fails. Any other Ideas.
January 22nd, 2013, 07:22 PM
Try pressing "Auto Night Light" then "0". Where is the nite light on your model?
OWNER RICK'S APPLIANCE REPAIR
REFRIGERATION SPECIALIST
January 22nd, 2013, 08:18 PM
Thanks Rick I tried that in the options, no good. The light is underneath the unit. Both bright and nite mode fails. You hear the relays clicking but no lights.
January 22nd, 2013, 08:55 PM
January 22nd, 2013, 09:05 PM
It's probably the relay on the control board that's faulty. Check for supply voltage going to the lights at the PCB between the orange wire and the brown/neutral wire. If you don't have a tech sheet I can draw you a diagram if needed.
Main Control Board WB27X10603 Order now for same day shipping. 365 day return policy. RepairClinic.com
January 22nd, 2013, 09:06 PM
I swapped out this board with another Working unit and the light still fails. What else could it be.
January 22nd, 2013, 11:25 PM
Originally Posted by
ibistony
Nothing else, except the bulbs or sockets. Check the voltage to the light at the board. One side of the lights is connected to Neutral and L1 comes from the PCB.
January 23rd, 2013, 03:36 AM
Thanks Rick. Can you draw me the orange & brown wire circuit and what should the voltage be.
January 23rd, 2013, 04:31 AM
rickgburton
Twins!!
Seperated at birth
By colorado roger in forum Whirlpool/KitchenAid
Last Post: February 26th, 2013, 02:27 PM
By jasminebay in forum Whirlpool/KitchenAid
Last Post: November 2nd, 2010, 08:09 AM
By ragmop in forum Whirlpool/KitchenAid
Last Post: August 9th, 2010, 11:11 AM
By Blackie in forum Sears Kenmore
Last Post: February 16th, 2010, 06:11 AM
By badlatch in forum Sears Kenmore
Last Post: February 25th, 2008, 07:34 AM
