Old May 13th, 2006, 12:52 PM
jaytango is on a distinguished road
Default GE Washer Fills but won't agitate, spin or drain.
My GE washer fills but when it stops and I close the lid it won't do anything. The timer runs the whole cycle, and I can hear the clicks of the various modes but nothing happens. I tested the lid switch for continuity and it works. I ended up testing each mode by jumping the contacts directly from the harness on the timer switch and every function actually works... it agitates, it drains, it refills and it spins... but only by manually jumping the leads, not on its own. Here's the weird part... first I connect the agitate lead - it agitates. Then I connect the drain lead - it drains. I then repeat this to rinse the clothes. I re-drain the machine then once the drum is almost completely empty it'll start spinning on its own and finish the spin cycle normally without my help. Any ideas what may be wrong?
Old May 13th, 2006, 04:30 PM
We need the model#, but I'm assuming its less than 10 years old?
It sounds like a bad contact in the timer assembly.
Old May 13th, 2006, 04:41 PM
Default Model #
Thanks for the quick reply. It's a GE WDSR2080D5WW. It's just under 2 years old.
Old May 13th, 2006, 04:50 PM
Its very rare to see this problem happen, but If i recall, I do think i remember seeing this happen before 1 time, and a new timer fixed it.
Here is the timer for your model you can order if you need to:
Timer asm washer
Old May 13th, 2006, 04:56 PM
Default I'll try that...
Thanks for your advice. I guess I'll have to order one of those.
Old May 13th, 2006, 10:50 PM
Ok, Sounds good.
Kenmore Elite Catalyst washer won't drain & spin Brittgee Sears Kenmore 1 August 24th, 2006 02:04 PM
Kenmore HD 70 Series, wont agitate - trips fuse box? - but will spin if on drain otherjohn Sears Kenmore 8 July 11th, 2006 09:22 PM
Whirlpool washer won't agitate...but will spin steph23 Whirlpool/KitchenAid 1 May 8th, 2006 04:38 PM
Washer does not agitate, spin, or drain NancyMc GE/Hotpoint 3 January 6th, 2006 06:52 AM
Kenmore Front Load Washer Won't Drain or Spin ed Sears Kenmore 3 March 20th, 2005 04:41 PM
