July 26th, 2006, 05:51 PM
Hotpoint Electric (1992) Hums, Won't Run
My Hotpoint electric dryer just hums when the timer is turned on, regardless of whether the door is open or the start switch is pressed.
The drum will turn by hand. It does not move by itself. The belt appears intact.
I checked circuit breakers. There's no smell. It worked fine yesterday.
Ideas, please?
July 26th, 2006, 06:00 PM
Addendum: The motor should not be getting power unless the door is closed (light out) and the start switch pressed. Correct?
July 26th, 2006, 06:17 PM
| goofyroo | Addendum: The motor should not be getting power unless the door is closed (light out) and the start switch pressed. Correct? |
You would be correct. It sounds to me like the motor switch is stuck on the run winding. You'll need a motor, unless you can get the motor switch still. If you let it hum, if it is indeed stuck on the run winding, it should shut itself down in 15 seconds or so on the motor overload. If it does, that's a sure sign. Let us know!
July 27th, 2006, 02:33 AM
Found it. Enough dust and dirt had accumulated around the wires and terminals of the motor, that the Start circuit was fully engaged anytime the timer was ON.
Apparently this drained the motor of its RUN power, as well.
Cleaned the motor and terminals with a vacuum, then a duster. Now it runs fine!
April 11th, 2009, 04:12 PM
By prodrumman in forum Antique and Retro Appliance Chat
Last Post: August 18th, 2007, 08:00 AM
By smsg3 in forum Sears Kenmore
Last Post: June 8th, 2007, 07:47 AM
