Go Back   ApplianceBlog.com - Appliance Repair Forums > Appliance Repair Talk > Microwaves > GE/Hotpoint
Old August 28th, 2006, 07:17 PM
kdh kdh is offline
kdh is on a distinguished road
Default GE JE1540WW mw fan running when door is open
My microwave fan and turntable are running when the door is open. I am not sure whether microvave is actually running with the door open, but I can hear the fan humming and turntable turning. If I close the door, the hum disappears. It seems to work properly (ie food is heated). The model is GE JE1540WW 003, and is about 8 years old. Any idea how to fix? Also is dangerous to continue to use, since I am not sure there's microwave when the door is open. Thx.
Old August 29th, 2006, 04:10 AM
2 common trouble makers....door switch/door switch mechanism or stuck/sticky relay on the control board.
I'd always go simple first and check the door switchs.
Would be a good idea to discontinue using it until the problem is corrected.
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Condenser Fan Direction thornyschizoid Refrigerators & Freezers 1 April 27th, 2008 12:46 PM
Kenmore Elite: freezer OK, food section too warm, air-damper is open. t2d Sears Kenmore 10 June 23rd, 2007 07:41 AM
Detergent Door will not open! Need wiring diagram. Bob Swerski GE/Hotpoint 11 July 10th, 2006 10:12 PM
compressor fan not running Timus Refrigerators & Freezers 2 July 17th, 2005 06:26 AM
