August 31st, 2006, 08:52 PM
GE Monogram
We have a GE Monogram s/s and the fan motor in the freezer keeps icing up and then will not run. What would be causing this?
September 1st, 2006, 11:09 AM
Whats the model#?
September 1st, 2006, 12:58 PM
I do not know what the model # is, I cannot find it on the frig anywhere and cannot find the manual either.
September 1st, 2006, 01:00 PM
This is a built in s/s with the condensor and fan on the top of the frig/freezer.
September 4th, 2006, 10:39 AM
Oh, so its a built-in model?
Sorry, I don't have any repair experience on built-ins.
Hopefully another tech. or member can help you out.
September 16th, 2006, 06:05 AM
water from condenser on top
sou nds like you have the same problem I have
I have a ZISB42DYb s/s builtin monogram
The ice comes from the top condesnor and drains into the freser, sometimes covering up the moters - it seems the drian gets cloged or does not work well
I can not see how the drain tube goes from the bottom of the condeser unit to the bottom of th evaprator unit
I suspect the bottom header is not keeping the watter flowing in the correct direction, to the rt to the evaporator
August 2nd, 2007, 05:10 PM
I see this post is very old. Have you solved the problem and what was it that was done? I am starting to work on Mono's and am trying to collect whatever feedback I can get...
August 6th, 2007, 07:55 PM
Originally Posted by
reeferman
Most of the time, the problem in this thread is caused by a clogged condensate tube. It could also be caused by a failed condensate pan heater, condensation build up on the evap compartment ceiling etc... The fix is a GE icing kit part# WR49X10021. It is a difficult job. Unless you have done many of these, I suggest you pass on this job and refer the customer to GE factory service.
August 20th, 2008, 05:52 PM
VERY common problem on GE built ins, model # ZISB or ZISW
Poor insulation of the upper evaporator box.
Ive seen some with a heater installed but it didnt do a very good job.
By pbear in forum GE/Hotpoint
Last Post: August 2nd, 2007, 05:13 PM
By wbuster1 in forum GE/Hotpoint
Last Post: March 29th, 2007, 07:29 PM
By ng622 in forum Ranges/Ovens
Last Post: December 5th, 2006, 10:23 AM
By conviso in forum GE/Hotpoint
Last Post: September 16th, 2006, 11:08 PM
By jldaddy in forum GE/Hotpoint
Last Post: August 19th, 2006, 09:35 PM
