Old October 14th, 2006, 04:13 PM
psdonald is on a distinguished road
Default GE Freezer Evaporator Fan ??
GE Fridge Model # GSS25XSNABS Mfg 1/30/03
Noticed this morning that items on upper level of freezer not frozen and also noticed that I didn't hear the fan that normally blows and shuts off as you open or shut the doors. After reading on this site, I unloaded freezer, unplugged and began to take the freezer apart. Removed back panel, found lower coils frozen, removed light cover, icemaker and finally got to the evaporator fan. It was not spinning. Defrosted with hairdryer, plugged back in but evaporator fan doesn't come on. Noticed when taking the evaporator fan out that it has a sensor that attached to condensor coil. Question, what triggers the fan to come on, how can I test to see if the fan is bad. Does the fan motor generally fail or is it related to the sensor.
Part number on the fan is WR60X10043.
With refrig plug back in frost is developing on the condensor coils, is that because the fan is not running or is something wrong with the defrost cycle?
Thanks for your help.
Old October 15th, 2006, 12:13 AM
Here is a link to a free GE online repair manual, Its excellent, lots of flow charts and diagnostic help:
http://www.applianceaid.com/ArcticaSxSfrig2.html
Old November 3rd, 2006, 09:26 AM
Default Ice Maker Stuck on Crushed
Replaced main control board and evaporator fan motor, put everything back together, evaporator fan works great, now all I get is crushed ice and water. Will not switch to cubed.
Is it a control board issue or did I possibly not hook something backup right.
Old November 3rd, 2006, 01:44 PM
First take out your ice bucket and move that metal arm up and down, it may be an ice clog in the blades, then move that piece that the metal arm goes into inside your freezer, move that up and down, it move freely.
Why is there a heater in my freezer? Lillian GE/Hotpoint 2 April 9th, 2007 07:03 PM
Freezer temp changes on Kitchen Aid Superba Pete V KitchenAid 3 April 9th, 2007 12:34 AM
Kenmore Coldspot Freezer Back-Panel Removal Godot Sears Kenmore 3 February 21st, 2007 11:50 PM
Chest Freezer Help Needed! skilowyo Refrigerators & Freezers 7 August 30th, 2006 06:29 AM
Kenmore Cold Freezer - Warm fridge Frost free failure rkgrp Sears Kenmore 4 April 4th, 2006 01:52 PM
