October 18th, 2006, 07:57 AM
GE Water Dispenser Tube Clogged
I have a 3 year old GE SS refrig. The ice maker works fine, but the water dispenser isn't working. I disconnected the tube going into the freezer door, pressed the dispenser lever and no water flowed so I replaced the water valve in back. Now water flows to the freezer door connector, but not through to the dispenser.
I thought maybe that ice had clogged the line so I used a hair dryer to try and melt it -- no luck. I tried shooting compressed air in the line, but no luck.
Here is my question: Does the tube go straight to the spigot or is there something else there like another valve, another filter or a reservoir?
If not, the tube must be clogged with something. Any ideas? How do I get access to it?
October 18th, 2006, 11:13 AM
Whats the model# of your refrigerator?
October 18th, 2006, 11:54 AM
Model #
The model number is GSS25SGPA SS
October 18th, 2006, 12:27 PM
No, you don't have an extra valve in your freezer door on your model.
I would just keep drying the hair dryer, it make take awhile to defrost, but you will eventually get it.
October 18th, 2006, 02:00 PM
Bad to worse
Thanks Jake,
I applied the hair dryer directly to the spigot. Two bad things happened; 1) now the trip switch (dispenser switch lever) doesn't work - no water, no ice, no soleniod opening the valve sound, nothing. I must have overheated it. and 2) the hair dryer stopped. By the way, the tube is still clogged.
I guess I should have taken the door apart and gone at the tube from the inside.
How do I access the trip switch and the tube from the inside?
October 18th, 2006, 07:59 PM
Here is a part diagram of your freezer door assembly:
http://www3.sears.com/imaging/ImageP...&titleID=00001
#93 just snaps off, then you can access the switch.
October 19th, 2006, 10:51 AM
Thanks -- I got it!!!
When I got back in there, the switch was OK but the heat had soften and mis-shaped the plastic dispenser level so it wasn't tripping the switch. I reheated it and bent it back.
Strangely enough, the water is now working as well. I guess the heat did melt through afterall.
Even though everything is currently working, I think I'll go ahead and replace the plastic parts I had to bend back.
October 19th, 2006, 08:32 PM
Good idea.
Glad the water is coming out good again.
February 16th, 2008, 10:09 AM
GE Model GSH25SGRB SS; Ice but no water
Would this thread apply to a GE Refrigerator model #GSH25SGRB SS. Ice maker IS working, however water dispenser in door is NOT. Thanks.
February 16th, 2008, 11:08 PM
Yes, but first check here and read in post#17 about what GE Jim says to do before anything else:
Too Cold, Mod No HSS25GFPD
By jxp_app in forum Amana
Last Post: February 8th, 2007, 10:49 AM
By batman in forum Frigidaire/Electrolux
Last Post: June 13th, 2006, 11:15 AM
By DarthMaul in forum Sears Kenmore
Last Post: June 7th, 2006, 09:06 PM
By mark o in forum GE/Hotpoint
Last Post: January 2nd, 2006, 09:22 AM
