Page 2 of 24 FirstFirst 123412 ... LastLast
Results 11 to 20 of 234
Thread: [FIXED] GE side by side fridge side not cold
  1. #11
    Jul 2005
    Post imported post
    Dan,
    Thanks for the response!!
    The model number is: TFX26KRDAWW. It is 5 years old this summer.
    Where would I find the wiring diagram?
    Does the fridge temp of 40 degrees seem like it's working?
    Freezer: 5 (1-9)
    Fridge: 7 (1-9)
    Wish I had a reference temp from before the problem....
    What is optimal fridge temp?
  2. #12
    Dan O.'s Avatar
    Dan O. is offline Appliance Tech
    Oct 2004
    Canada
    Post imported post
    It is often located in a small pocket, pouch or envelope behind the kickplate. On some models it may be in an envelope at the back, maybe in the compressor compartment or even pasted right on the back of the cabinet. On the very newest, electronically controlled models (not yours), inside the control panel.
    Does the fridge temp of 40 degrees seem like it's working? What is optimal fridge temp?
    It depends on how cold you like your beer. Anywhere from ~34°F to 42°F is usually acceptable *food* temperature in the fridge compartment. The colder the temp, the longer food will generally last.
    BTW. To properly test "food temperature", place a jar, etc. 1/2 - 3/4 full of water on a middle shelf and test that water's temperature after ~12 hours. Each time you adjust the controls you'll need to wait that length of time before getting an accurate reading again.
    JFYI
    Dan O.
    Appliance411.com
    =D~~~~~~
  3. #13
    Jul 2005
    Post imported post
    Thanks for the info, Dan. I'll toast you with a Molson at 37 degrees...
    Kevin
  4. #14
    solshopping is offline Member
    Jul 2005
    Default I have similar problem with GSS22WGMCWW
    Jeff,
    My GE model has the fridge side warming up. I had a service tech fix it and he blow dried the frost out in the freezer and put in a new heater and bracket. After 4 months it started failing again. I thought that the heater and bracket asm failed again so I bought a new one and replaced it myself. I thought that fixed it but 1 week later it started up again. Now I just blow dry the fridge weekly. Can you please help in diagnosing the issue?
  5. #15
    Quote Originally Posted by solshopping
    Jeff,
    Thats very uncommon to see yours do that, is the complete evaporator coil frosted up when you defrost it?
    Jul 2005
    Default solshopping problem
    Quote Originally Posted by Jake
    Thanks for responding.
    Yes. The whole evaporator coil is frosted.
    Is there a defrost timer with this model?
    SolShopping
  7. #17
    Your model has the defrost timer as part of the motherboard, This may explain the problem, i have had to change the motherboard on some of these G.E.'s due to various problems.
    Check your owners guide, you may have a extended part warranty on this motherboard.
    Jul 2005
    Default Motherboard install
    Is this easy to do? Replace the motherboard. The fridge is 4 years old. I don't have extended warranty. I guess I have to shell out 100.00$ for the motherboard.
  9. #19
    But first check your owners guide, some control boards have a 2-5 yr. part warranty.
    Its abit cheaper here:
    Main control board
    Attached Thumbnails Attached Thumbnails [FIXED] GE side by side fridge side not cold-motherboard1042206.jpg
    WASE4220 is offline Member
    Mar 2006
    ATX
    Angry My GE fridge side also not cold enough!
    I also have same problem with my GE TFX22CRDA. Couple weeks ago i defrosted evaporator coil which was covered evenly form top to bottom like snow-like frost. Today the evaporator coil had the same snow-like frost again, so i defrosted again. The fan is good and cool air is coming into the fridge side OK. But i think this will last about a week before i stop cooling again. There is no water problem. The water dispensor is working fine. Or any sign of unusual noises. So any idea would help, thank you.
    P.S. My name is David.
  1. kenmore elite fridge side not cold
    By EdBurkett in forum Sears Kenmore
    Last Post: November 22nd, 2008, 09:41 AM
  2. Jennair fridge side not cold after defrost
    Last Post: September 20th, 2006, 12:48 AM
  3. ge profile performanceside by side fridge side not cold
    By jeffreyrae in forum GE/Hotpoint
    Last Post: September 9th, 2006, 11:17 PM
  4. msd2465ge - Fridge side not cooling
    By MarkF2 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 31st, 2006, 11:43 AM
  5. Side X Side Fridge Still Doesn't Get cold Enough
    By hog100 in forum Refrigerators & Freezers
    Last Post: July 22nd, 2005, 03:53 AM
