LinkBack (2) Thread Tools Search this Thread Display Modes
Old June 29th, 2005, 12:51 PM
jeffricha is on a distinguished road
Post [FIXED] GE side by side fridge side not cold
My GE side by side fridge is not up to par on the fridge side. The freezer seems good but a few weeks ago I noticed some water below in the front of fridge on floor and now the fridge side is not cold enough. I turned the dial up to 9 and it still seems warm. Any thoughts?
Old June 29th, 2005, 04:21 PM
Post imported post
Model#?
Evaporator fan in the freezer working? Any frost on the freezer back wall?
Some common trouble makers.... http://www.applianceaid.com/frig_notcold.html
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old June 29th, 2005, 06:05 PM
Post imported post
Found some frost on back wall and I can hear the fan and feel air at vent control in fridge side. I wonder if I let it defrost long enough. Or is it possible the defrost unit is malfunctioning.
Old June 29th, 2005, 08:33 PM
Post imported post
**I wonder if I let it defrost long enough. Or is it possible the defrost unit is malfunctioning**
One way to tell...access the cooling coils ( evaporator ) in the freezer and let us know what you see....
Pic from Appliance411
Pic from ApplianceAid
JRAppliance
Old June 30th, 2005, 11:56 AM
Post imported post
I took cover off as recommended and you were right Jeff1. Thanks
Old June 30th, 2005, 07:23 PM
Dan O.'s Avatar
Post imported post
jeffricha wrote:
Was the evaporator coil totally frosted up or just partially frosted like in the photo above?
Dan O.
Appliance411.com
=D~~~~~~
Old July 1st, 2005, 01:36 AM
Post imported post
It did have quite a bit of ice. The thermostat was faulty and replaced.
Old July 1st, 2005, 12:26 PM
Dan O.'s Avatar
Post imported post
jeffricha wrote:
Clear "ice" or white snow-like "frost"? It is an important distinction when dealing with refrigerator problems.
Was the build-up uniform across the whole evaporator coil or just on part of it like the picture shown above? If just part of it, you may have other problems as well.
The defrost termination thermostat I assume??
Glad to hear you found the defective part. Hopefully it was the only problem.
Dan O.
Appliance411.com
=D~~~~~~
Old July 18th, 2005, 11:01 AM
idloveaguinness is on a distinguished road
Post imported post
Glad I found this board.
I have a GE with similar problems. I first noticed that the fridge was not cooling as well as it should (freezer seemed fine)...put a thermometer on the middle shelf and it registered at 55 degrees - not good.
I vacuumed out underneath the fridge of some (but not much) dust and cleared ice out of the upper and lover pass-throughs (most of it was in the lower, which was completely blocked). I also removed the back cover of the freezer and found snow-like frost (no ice) on the bottom 1/2 of thecoils (looked just like the photo above). There was ice 'pooled' up in the bottom of the freezer, but the drain hole was not plugged. There was also a pool of water in the bottom of the fridge.
The fan at the top of the freezer is blowing...but I haven't heard the fridge make any other noises the last couple of days....just the quiet hmmm from that. Ido not think I hear a compressor turn on and off.
I used a hair-dryer to takethe snow off and put it all back together...this was yesterday. Today (18 hours later) the fridge is down to 40.
A couple of questions: 1. I see two hanging wires (one white, one grey)with male terminals coming from up top and resting on the top of the cooling coils behind the back panel. They do not seem to go anywhere.- what are there and could they be part of the problem?
2. Should I give it another day to see how all works out?
3. Is there something else I should try?
I am fairly good with little 'fix-it' projects, including wiring,and would prefer saving $$ on a repair man - UNLESS this is surely one for the pros.
Kevin
Old July 18th, 2005, 04:31 PM
Dan O.'s Avatar
Post imported post
idloveaguinness wrote:
Since you haven't told us which model of GE refrigerator you have (they're not all the same), it is impossible to say without being there ourselves to check it out. But you'd likely have to check the wiring diagram right on the fridge itself to determine what those wires are for.
JFYI. You can read about where to locate the model and serial number identification tag on your appliances at the following link:
LINK > Model Number Tag Search
Today the fridge is down to 40... Should I give it another day to see how all works out?
If it seems to be working, I don't see why not.
JMO
Dan O.
Appliance411.com
=D~~~~~~
LinkBack to this Thread: http://www.applianceblog.com/mainforums/ge-hotpoint/701-fixed-ge-side-side-fridge-side-not-cold.html
Posted By For Type Date
GE side by side fridge side not cold - Page 2 - ApplianceBlog.com - Appliance Repair Forums This thread Refback September 21st, 2009 04:59 PM
GE side by side fridge side not cold - Page 3 - ApplianceBlog.com - Appliance Repair Forums This thread Refback September 8th, 2009 08:34 PM
kenmore elite fridge side not cold EdBurkett Sears Kenmore 7 November 22nd, 2008 09:41 AM
Jennair fridge side not cold after defrost wobbletop Maytag/Magic Chef/Admiral/Jenn-Air 7 September 20th, 2006 12:48 AM
ge profile performanceside by side fridge side not cold jeffreyrae GE/Hotpoint 3 September 9th, 2006 11:17 PM
msd2465ge - Fridge side not cooling MarkF2 Maytag/Magic Chef/Admiral/Jenn-Air 6 August 31st, 2006 11:43 AM
Side X Side Fridge Still Doesn't Get cold Enough hog100 Refrigerators & Freezers 5 July 22nd, 2005 03:53 AM
