Old January 4th, 2007, 01:04 PM
sregan is on a distinguished road
Default Fridge not cooling enough but not defrost problem
I've got a 10 year old GE 21 Cf and the freezer temp is about 40. The compressor runs hot enough to burn my finger. If I give the compressor a break for about a half hour that's been enough to get it working again for a few days (freezer temp below 0) then same thing.
Old January 4th, 2007, 03:26 PM
Senior Member
szm200 is on a distinguished road
Sounds like a partially clogged capillary to me. An amp probe check of the compressor draw would confirm this.
A filter change with internal fine mesh sceen and capillary blowout would fix it.
Old January 4th, 2007, 07:04 PM
Hey szm200,
Thanks for the reply. Does the fluid (freon?) get dirty inside the sealed system? Is there an internal filter?
When the problem started I cleaned the condenser tubing it was extremely dust clogged.
Old January 5th, 2007, 03:59 AM
Senior Member
It's possible you have a low side leak . Under these conditions the freon level will get down low enough for the compressor to start sucking in air. Eventually the capillary line will clog up.
Help needed again for Maytag 1502ARW Katiemay Maytag/Magic Chef/Admiral/Jenn-Air 16 November 4th, 2006 11:09 PM
Jennair fridge side not cold after defrost wobbletop Maytag/Magic Chef/Admiral/Jenn-Air 7 September 20th, 2006 01:48 AM
msd2465ge - Fridge side not cooling MarkF2 Maytag/Magic Chef/Admiral/Jenn-Air 6 August 31st, 2006 12:43 PM
water leak in fridge (top) during defrost cycle mackal Frigidaire/Electrolux 4 July 15th, 2006 12:57 AM
