Results 1 to 4 of 4
Thread: GE washer makes Loud thumping noise
    dadsway is offline Member
    Jan 2007
    olive branch
    Default GE washer makes Loud thumping noise
    Have a GE washer model S4200B0WW that makes a loud thumping noise
    when using slow agitate and slow spin it operates ok with regular agitate
    or fast spin is this the motor or transmission? or something else?
    You would need to open up the front panel and see if you can pinpoint where its coming from, you can take the belt off the motor and transmission pulleys and run in slow and see if the sound is still present with the belt off.
    Read #1, #2, and #3 here:
    http://www.applianceaid.com/genew.html
    for more help and how to access the inside parts.
    Jan 2007
    olive branch
    Took the belt off the motor and transmission, the noise is coming from the
    motor. Does this mean its the motor or clutch. Or is it just best to replace
    with the motor and clutch kit?
    Its always better to replace the whole assembly, you can order it here:
    2 Speed motor & clutch kit
  1. Maytag mav7000aww Top loading washer loud clicking noise during spinning
    By alan509 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 23rd, 2007, 05:18 PM
  2. GSS25SGRE 22 - Freezer makes loud humming noise
    By BuzzBomb in forum GE/Hotpoint
    Last Post: April 17th, 2007, 10:02 AM
  3. loud ge washer spin noise
    By sun45 in forum GE/Hotpoint
    Last Post: September 22nd, 2006, 10:56 AM
  4. Replies: 7
    Last Post: August 9th, 2005, 11:58 AM
  5. Frigidaire Washer Emits Loud Electronic Buzzing Noise
    By homeboy in forum Frigidaire/Electrolux
    Last Post: June 20th, 2005, 07:14 PM
