Results 1 to 3 of 3
Thread: Here's my story on the water line freeze up problem
    Chip is offline Member
    Oct 2006
    Virginia
    Default Here's my story on the water line freeze up problem
    My water line began freezing in October after 2 years of perfect operation. Since my unit was out of warranty, I followed the posts here, even submitting some of my own, with no real solution to the problem. I became an expert at defrosting, only to have the line refreeze. I finally went to the GE site and submitted an Email to customer service stating my dissatisfaction with the water dispenser. They contacted me promptly, and over the phone diagnosed that there was a problem with the insulation in the door, and they would replace it at no charge. It appears that the door was reengineered about 3 years ago to solve a moisture problem, and was made thicker, with insulation sprayed in and the door itself sealed. However, in some of the doors, the dispenser tube actually got displaced when the insulation was sprayed, placing it closer to the inside door panel, and therefore closer to the 0 degree freezer air. The new door was shipped directly to my home, and, as instructed, I called to have a technician come by to install. The only negative here is I was led to believe this wouldn't cost me anything, but I did end up paying for a service call. I hope this helps.
    danghoff is offline Member
    Apr 2013
    McKinney, TX
    Chip, How did you find someone at GE that would talk with you about your problem? Thanks, Dan Hoff
    Read this thread:
    GE Water Dispenser Line keeps freezing up ...
    You can contact GE as a member in that thread did to see if they will replace your door free of charge.
    We have a GE Rep. here as a member:
    http://www.applianceblog.com/mainfor...sponse-ge.html
    Here is the email of our Rep.
    eresponse@ge.com
    Keep us posted.
    If they don't replace your freezer door, This heater kit should work on your model.
    GE Water dispenser heater kit:
    Manufacturer part number WR49X10173 is RepairClinic item number 1381601
    It comes with instructions to install it.
  1. Kenmore refrigerator water dispenser drips
  2. GSH25KGMC Water Dispenser Problem
    By TripleJackInGA in forum GE/Hotpoint
    Last Post: February 2nd, 2007, 10:54 PM
  3. Whirlpool Gold water drip from dispenser
    By wiznkids in forum Whirlpool/Roper/Estate
    Last Post: November 30th, 2006, 09:31 AM
  4. GE Profile water dispenser line leaking
    By dlynch in forum GE/Hotpoint
    Last Post: October 4th, 2006, 08:17 PM
  5. Water Line problem
    By gusrobin in forum Whirlpool/Roper/Estate
    Last Post: December 28th, 2005, 05:21 AM
