Old February 28th, 2007, 07:33 PM
askimbo is on a distinguished road
Thumbs down GE bottow freezer; fridge is warm
I've been reading thru your forums and have checked for a few common problems but am still stuck.
I have a GE Model # GBS22LBMACC, the freezer works fine (10 degrees) but the fridge is a toasty 48 degrees. I cleaned the dust off the coils underneath the bottom of the unit, and I checked the cooling coils in the back of the freezer and they look good (few tiny spots of ice but 99% frost/ice free). The fan that circulates the air in the freezer seems to blow around a lot of cold air, the fan in the back/outside is blowing around a lot of hot air. There is even cold air blowing out the vent in the fridge (the air seems to be about 35 degrees with the thermostat turned all the way to the coldest), but it must not be enough air or cold enough because it's always so warm in there. The doors seal fine.
What else do I need to check? Do I need to check the damper door between fridge and freezer and how would I get to that? Could it be the thermostat for the fridge?
Adam
Old March 1st, 2007, 06:49 AM
Not fine, should be 0ºF.
Not fine, should be completely covered with a thin layer of frost when running.
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Kenmore fridge bottom freezing; freezer warm; no water bkmason Sears Kenmore 12 May 28th, 2007 11:00 AM
Kenmore side-by-side...fridge side warm but freezer side fine jpp816 Sears Kenmore 18 May 18th, 2007 11:17 AM
596.77277790 Fridge OK, Freezer warm JimB Sears Kenmore 5 December 13th, 2006 01:00 PM
Kenmore 253 SxS warm freezer fridge ok Zebra1 Sears Kenmore 3 July 25th, 2006 06:31 PM
Kenmore Cold Freezer - Warm fridge Frost free failure rkgrp Sears Kenmore 4 April 4th, 2006 01:52 PM
