January 15th, 2005, 09:14 PM
imported post
I have a GE Triton dishwasher model number GSD5320D01 and it will not drain all the water out of the dishwasher. We have checked for clogs and have taken the drain hose off the garbage disposal. The water is pumping out. I don't know how much pressure there should be, but it is about as much pressure as a faucet puts out. What do you suggest we try? It seems as though there isn't enough time to let the water drain.
Thanks Tammie
January 15th, 2005, 11:22 PM
imported post
This thread will give you some ideas of what it might be:
http://www.applianceblog.com/forums/forum6/34.html
Let us know if that helps ya.
January 16th, 2005, 08:45 AM
imported post
Thanks for the link; however, I had already seen that post. We do have water pumping out.
Tammie
January 16th, 2005, 10:57 AM
imported post
tammie wrote:
GE Triton dishwasher ... will not drain all the water out ... We do have water pumping out.
There are 2 fairly common things used on your model D/W which can cause incomplete draining. Behind the bottom rack there is a filter screen with 4 screws holding it in place. Below that is the unit's 'check valve'. There is a part inside the check valve called the "piston and nut assembly" (see the link below) which unscrews. It should move freely up and down. If it doesn't seal completely, the D/W won't pump out correctly and in some cases not at all.
LINK > GE D/W Piston and Nut Assembly
The other is a 'flapper valve' inside the exit port of the auxiliary (smaller, secondary) pump. When it fails, it can allow drain water from the drain hose settle back into the tub's sump after the pump stops turning.
LINK > GE D/W Auxiliary Pump Flapper Valve
The piston and nut assembly seems to be the more frequent cause of partial or intermittent draining problems.
JMO
Dan O.
Appliance411.com
=D~~~~~~
January 18th, 2005, 04:08 PM
imported post
You are a genius. Thank you. It was the piston and nut assembly and we now have a very happy dishwasher (me and the GE).
January 19th, 2005, 02:19 PM
imported post
Glad to hear it, thanks for the follow up.
Dan O.
Appliance411.com
=D~~~~~~
February 7th, 2005, 04:38 PM
imported post
I have a GE Triton XL dishwasher Model # GSD6700G00BB and am having the same issue as Tammie. Beginning today, the water is not draining completely. I checked the drain vent for the dishwasher to make sure there was no debris in the pipe and there wasn't so that was not the problem.
The screen at the bottom of the dishwasher is not secured by 4 screws, it is flush with the bottom of the dishwaher. How do I check to see if the piston and nut assembly is the issue?
Deborah
February 7th, 2005, 06:25 PM
imported post
**How do I check to see if the piston and nut assembly is the issue?**
Your shouldn't have one.
Most of this stylerequire pulling the d/w out and laying it on it's back to check the drain pump for any gookus or build ups.
February 12th, 2005, 09:19 PM
imported post
My husband checked for any buildup in the drain pump and couldn't see any. We decided to run the dishwasher again (empty and without adding detergent) on normal wash to see if it would drain; it did not drain and we noticed some soap suds which surprised us since we not only did not add d/w detergent, there had not been any detergent all week since we hadn't used it since it stopped draining several days ago.
Any ideas why it would do this? Thanks
August 14th, 2005, 10:58 PM
Problem Solved! Thanks
We have a GE Triton III dishwasher, model GSD5620, purchased and installed in our new home about 5 years ago. Several months ago, my wife noticed that the tub wasn't pumping out all the way at the end of the cycle. Recently the water had become rather soapy, and she complained that the whole prospect just didn't seem to be too hygienic. I just had to agree!
I got out my trusty screwdriver (and a few other tools) and removed the lower spray arm, then the water return basket filter. I got a bunch of goo outa there (kinda looked like digested cat hair - - yechhhh!), and I figured my problems were over! No such luck, bucko!! Never underestimate the "quality" of American products! That a $600 dishwasher could be rendered helpless at 5 years by an $11 part (actually, most of the piston assembly is fine - it's just the cheap rubber flapper gasket on there that has decomposed - must be all of about 10 cents worth of materials). I'l betcha Bosch and Miele wouldn't tolerate such sloppiness. Oh well - I digress.
My main reason for posting this is to make it easier for the next guy to solve the same problem by pointing out the exact location of that little Piston Assembly Check Valve. To that end, I have included this photo that I hope will be helpful.
See the post above from Dan O for vendors supplying the needed parts!
Thanks again! Merlin
By rickm in forum Whirlpool
Last Post: October 3rd, 2011, 04:14 PM
By shrimpsiumai in forum GE/Hotpoint
Last Post: June 9th, 2007, 09:59 AM
By oiram in forum Sears Kenmore
Last Post: February 8th, 2007, 10:54 PM
By jsevinsk in forum Dishwashers
Last Post: November 21st, 2006, 07:01 PM
By soriold in forum Dishwashers
Last Post: July 11th, 2006, 11:21 PM
