June 8th, 2007, 12:55 PM
Defrost Timer Location
My side by side, model 363.9542613, has heavy ice buildup on the coil at the rear of the freezer. I have been told that the most likely cause is a defective thermostat and/or defrost timer. I have purchased both parts and replaced the thermostat easily but can't find the defrost timer... help!
June 8th, 2007, 01:22 PM
Defreost timer is located in refrigerator section, back wall next to and to the right of the cold control. More common than the defrost timer or defrost thermostat going out is one of the defrost heaters being bad. There are two glass tube heaters on the evaporator connected in series. Check those first. If you find one is bad, replace both.
Rick
OWNER RICK'S APPLIANCE REPAIR
REFRIGERATION SPECIALIST
By tony fanucchi in forum GE/Hotpoint
Last Post: June 20th, 2007, 12:03 AM
By dave99 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: December 26th, 2006, 10:18 PM
By ccomt in forum GE/Hotpoint
Last Post: October 5th, 2006, 05:23 AM
By ekcwmi in forum GE/Hotpoint
Last Post: February 15th, 2006, 11:53 AM
By Elizabeth in forum GE/Hotpoint
Last Post: February 2nd, 2006, 04:50 PM
