Results 1 to 3 of 3
Thread: Rainbow Vacuum cleaner repair
    pinkertonpv is offline Premium Member
    Dec 2009
    Alabama
    Default Rainbow Vacuum cleaner repair
    I have a 6 year old Rainbow system, Model E2. I stepped on the cord as I was carrying it downstairs and pulled the cord out of the unit. Still attached but the motor will not turn on. I am handy with tools and have repaired electrical appliances, but I am having difficulty disassembling the Rainbow unit. Only a few screws visible after the water bowl is removed. Maybe held together by snaps, etc, but I cannot see any obvious locations and don't want to just pry away. I have found schematics on the web , but no repair directions yet. I have searched this site and found only two post. One mentioned the prying apart which I might have to do. Hope I can get some disassembly instructions.
    Anyone ever disassembled a Rainbow before. Can you get me started. Any help will be greatly appreciated.
    Dec 2009
    Alabama
    Default Update on Rainbow repair
    Update on the Rainbow repair.
    I found 4 additional screws under the two clear plastic side panels with the golden paper inserts. After figuring out how to pry these two plastic inserts off, there were 2 screws under each one. Took those out and the plastic shell came off the unit exposing the motor and all the extras. Cleaned the dust and foreign matter out of the motor housing and other places, blew the dust off the shop vac type paper filter protecting the motor and generally cleaned everything in sight. Oh yeah, repaired the electrical cord. There is an electrical fitting with 4 wires running into it that fits in a socket that had become loose. In addition, I found a safety switches to keep the motor from running when the water bowl is off. Rainbow works fine.
    Ok, sounds good, I don't know much about vacuum cleaners or I could have assisted you.
  1. Replies: 8
    Last Post: July 20th, 2009, 03:49 PM
  2. Disassembling of vacuum cleaner
    By delroy in forum General Appliance Chat
    Last Post: February 23rd, 2009, 08:27 PM
  3. Major Appliance Repair Service?
    By Dee341 in forum Appliance Stores & Service Complaints
    Last Post: November 18th, 2007, 10:37 AM
  4. Sounds like a Vacuum Cleaner
    By Snow_Badger in forum Bosch
    Last Post: March 9th, 2006, 12:09 PM
  5. dealing with unethical repair svc?
    By gellfex in forum Washers
    Last Post: September 20th, 2005, 11:08 PM
