May 19th, 2012, 09:31 AM
whirlpool dehumidifier ad0302xm 30 pt
Even though its aged, this dehumidifier does not have much run time. When I cleaned and lubed the fan motor, and restarted, the fan does not kick in. When I try to spin it by hand, it gives slight resistance. Does this mean the bearing is bad? Also, I see the fan motor is $100. Is this more then the unit is worth to fix?
thanks
May 19th, 2012, 08:06 PM
Missing a digit.
If stiff to turn, yes.
Fan motor comes up as NLA for me.
May 20th, 2012, 10:34 AM
the unit is ADO302xm0
serial - H51574658
30 pt
7 amp
The fan motor is 115v 60Hz .5A
1550 rpm cont air over
Franklin Electric
Jacksonville AR
another marking on the fan motor is 82535I0680 12.5MHP
thanks
May 20th, 2012, 10:41 AM
I see the manufacturers part number is 1162508, based on schematic, but the unit is not available. However, on another website, I see they have several different aftermarket motors.
May 20th, 2012, 02:27 PM
After market is likely the only style you can get.....duoble check the shaft size, mounting, direction the motor runs, amp draw and speeds.
I use a lot of these for one speed motors, they are a replacement...
Fan motor, clockwise Manufacturer part number D120
Fan motor. Counter Clockwise Manufacturer part number D121
By Spinman in forum Window & Room Air Conditioners
Last Post: May 31st, 2011, 07:43 PM
By Instantaneous in forum HVAC
Last Post: May 25th, 2010, 02:25 PM
By Larry Tippner in forum Whirlpool Reviews
Last Post: June 18th, 2009, 05:42 AM
By fiddelke in forum General Appliance Chat
Last Post: May 17th, 2009, 09:27 AM
By JayJay99 in forum General Appliance Chat
Last Post: September 27th, 2007, 02:41 PM
