Results 1 to 4 of 4
Thread: GE Triton GSD5500 leak
    dseelb is offline Member
    Nov 2007
    Flat Rock NC
    Angry GE Triton GSD5500 leak
    My 4 yr old washer had a frustrating occasional small leak of soapy water on the floor. It was tolerated for awhile because it was only once or twice a week, and I could not find any source by inspection with front panels removed. when it became worse over time, I described all symptoms to a local service professional and was told he couldn't help because "it was a common problem, and GE did not have any solution or recommendations". My floor and baseboards were deteriorating, and I was sick of sponging up the mess! I pulled the unit out and discovered the problem was a poorly (incompetently?) designed connection where the water supply to the spray arm at the very top of the cabinet was leaking and running down the left side of the cabinet. I removed the very sticky sealer that was leaking, and obviously intended as a "patch", where the Part #571 (Hose Power Shower) entered the cabinet top. It is a soft plastic elbow with a flange that is squeezed and pushed through a hole to feed water to part #570 (Spray Arm 3rd Level). There is no mechanical clamping of this connection. It is inevitable that the sealer will eventually degrade and the connection will leak! A homemade washer 1/16 thick, with hole to match elbow flange outlet, and sized to fit into arm assembly recess, provided the mechanical clamping needed, and the problem was solved. This solution may not be permanent, as it depends on the plastic dishwasher housing to remain sufficiently ridgid to maintain clamping integrity. THIS CONNECTION WAS DESIGNED TO FAIL! SHAME ON GE! I cannot believe but all owners of units with this design will not suffer in time! I hope this helps you, because your repairman (and GE) may not. ....Dave
  2. The Following User Says Thank You to dseelb For This Useful Post:
    weiqunz (November 29th, 2011)
  3. #2
    daddyjohn is offline Appliance Tech
    Oct 2007
    Tennesee
    I wonder if some silicone or RTV would help make it more permanent?
  4. #3
    Nov 2007
    Flat Rock NC
    Thanks, I did silicone the connection at the top of the cabinet. Time will tell ! Only 4 wash cycles completed. OK so far. .. D
  5. #4
    Quote Originally Posted by weiqunz View Post
    weiqunz has reported a post.
    Reason:
    Post: GE Triton GSD5500 leak
    Forum: General Electric Reviews
    Posted by: dseelb
    Original Content:
    weiqunz, ask here in this thread.
  1. Whirlpool ThinTwin Washer Leak from bottom
    By g4shiv in forum Whirlpool/KitchenAid/Roper
    Last Post: September 11th, 2011, 03:16 PM
  2. Door Leak on KUDS25SH
    By mafopinion in forum KitchenAid
    Last Post: April 9th, 2007, 12:08 PM
  3. Kenmore elite 90 series leak
    By califix in forum Sears Kenmore
    Last Post: November 5th, 2006, 10:38 PM
  4. GE Profile pinhole leak
    By Chris in forum GE/Hotpoint
    Last Post: October 27th, 2006, 09:09 PM
  5. Amana sxs freon leak.
    By gamefish in forum Amana
    Last Post: July 22nd, 2005, 08:38 PM
