Old August 12th, 2007, 12:09 PM
eewoz is on a distinguished road
Default KitchenAid Oven troubles
My KEBC171KBL oven no longer heats. It is a little over 1 year old. I recently did a clean cycle and gor F5 E5 error code. I do not believe it has worked since. I would appreciate any advice on how to go about trouble-shooting this oven. Also, are there any places on the web or any books that give a general overview of the circuitry inside a typical oven? Thank you.
Old August 12th, 2007, 10:50 PM
There should be 2 more numbers after the L at the end of your model#, then I can give you a service sheet/wiring diagram link.
Old August 13th, 2007, 11:43 AM
I believe it is 06.
Thank you.
Ed
Old August 13th, 2007, 11:51 AM
I would be cutting power to the range, pulling it out, removing the back panel and checking the fuse, reference # 37 in this breakdown, these open if the ovens get too hot, usually after a self clean cycle has been run...part number is 9759242
Old August 13th, 2007, 11:57 AM
However looking at your tech sheet it is not showing a F5-E5, let me look further, this might go back to the oven control, but have to find what that code means..are you sure of those numbers???
Old August 13th, 2007, 04:00 PM
You are right on that one! It was indeed the over temp thermostat. I ordered a replacement and should be back in business by the weekend! Thank you for your help.
Old August 13th, 2007, 04:03 PM
Yes I am sure about those numbers. When I took the oven apart the repair instructions that I found inside did not list that error code either, so who knows. As I said in my earlier post however I found the problem to be the overtemp thermostat. Thanks again.
Old August 13th, 2007, 04:04 PM
I located the schematic inside the oven housing when I took it apart. I am all set for now. Thank you for your response.
You are welcome....
KitchenAid Electric Oven does not work ds2 KitchenAid 14 April 10th, 2009 03:02 PM
KitchenAid Superba Oven Dim Control Display Arnhemjim KitchenAid 3 June 10th, 2007 07:41 PM
Kitchenaid kebs208dss10 double oven trouble Ann Foust KitchenAid 1 April 5th, 2007 09:20 AM
KitchenAid Superba KEMS307D8S6 Oven problem jbow345305 KitchenAid 1 March 24th, 2007 09:32 PM
Kitchenaid Oven F3 Code DJUecker KitchenAid 1 February 20th, 2006 07:21 PM
