have a kitchenaid KGST307HBS9 gas oven. It's about 2 1/2 years old. I turn the oven to 350 degrees, after it reaches 350 it shuts off and gives a F7E0 code and turns off. I tried different temps and it does the same thing. I even tried self cleaning, it keeps making a clicking noise and gives the same code.
Someone pls help!! thanks |
F7 E0 error says problem with the latch switch:
Here's the service sheet on it: http://www.servicematters.com/docs/w...%209754241.pdf Here's the parts diagram for your model: KGST307HBS9 Diagram#8 part location#7 is the oven latch/lock assembly, thats likely what will need to be replaced, as I have replaced a few for this same issue your having. Its located in the back of you range, so you would need to pull it out from the wall and remove the back access panel, then you will see it towards the top. Unplug/Turn your breaker off to your range first. Jake
| KitchenAid Superba KEMS307D8S6 Oven problem | jbow345305 | KitchenAid | 1 | March 24th, 2007 09:32 PM |
| F3 code repair on Kenmore oven | Cwanger | Sears Kenmore | 12 | February 25th, 2006 09:51 PM |
| Kitchenaid Oven F3 Code | DJUecker | KitchenAid | 1 | February 20th, 2006 07:21 PM |
| KitchenAid "SAb" fault code | emergence | KitchenAid | 1 | November 25th, 2005 11:31 AM |
| KitchenAid Range Error code F1:E3 | Katy | KitchenAid | 7 | October 18th, 2005 03:50 AM |
