Old March 20th, 2008, 05:47 PM
Howardm is on a distinguished road
Default KA KTRP18KDW05 ice mkr inlet was frozen-now no water flow
All,
I have a Kichenaid Model KTRP18KDWH05 Frig. Ser# EF0622814 Prod. 02-96
The ice maker quit working a few days ago. I found the water inlet tube completely frozen up. I cleared the ice plug with the help of a hair dryer.
I then removed the water filter that is in-line from the bottom of the frig to the inlet of the ice maker. It is free and clear. I put water in the filter with a turkey baster and it went all the way to the ice maker tray.
I filled the ice tray with water and it promptly made ice and dumped them in the ice bucket.
I suspect the water valve is not operating, but I don't know how to test it. I'm an automotive engineer, so I have the DVOM's and understanding to test if someone can help.
I also pulled the cover off the front of the ice maker module (note, I did not mess with the gear at all). I did notice about a 1/4" dark/burn type mark toward the outside of the big gear on the module. Does this mean anything? I'll take a picture of it and post for reference if necessary.
Thanks for the assistance.
Old March 21st, 2008, 12:43 AM
You can test your water inlet valve a couple of ways, I usually use a jumper wire to jump L & V here:
http://www.applianceaid.com/icemaker-modual.html
and that will energize the water inlet valve to open and let water in, if no water comes in when you jump L & V, pull your refrigerator out from the wall, then take off the lower back access panel, then unmount your inlet water valve from your refrigerator cabinet, then take off the electrical connector from the water inlet valve, then put your volt meter leads in that connector, and jump L & V again, and notice if your meter reads 120 volts.
Yes, please upload a photo of that 1/4" dark/burn spot on your ice maker module.
Old March 21st, 2008, 11:39 AM
Default Picture of burn mark on controller gear
Thank you very much .
I'll check the valve tonight and let you know the results.
I have also uploaded a picture of the "burn?" mark on the controller gear.
KA KTRP18KDW05 ice mkr inlet was frozen-now no water flow-p3200079-compressed.jpg
Old March 21st, 2008, 12:14 PM
Its hard to see, can you make it bigger? Max photo size here is 850.
Old March 21st, 2008, 12:18 PM
Default Bigger picture
Little bigger.
Old March 21st, 2008, 12:25 PM
Thanks, much better.
Yes, its burned pretty good, looks like you'll need a new ice maker assembly, but do check the voltage to your water inlet valve first.
Here's the ice maker assembly for your model, it's on sale here:
Manufacturer's Number: 4317943
New Kenmore cooling questions and Ice maker water flow. gottria Sears Kenmore 7 November 30th, 2007 03:03 PM
ge ice water dispenser not working thomasebud GE/Hotpoint 3 September 25th, 2007 06:58 PM
Bosch DW and tankless water heater JDR Bosch 1 September 7th, 2007 05:21 PM
Whirlpool ice maker water fill tube and cup freezing up NDS Whirlpool 10 July 27th, 2007 01:23 AM
Whirlpool Conquest Ice Maker, no water Euro-Tour Whirlpool 1 March 14th, 2007 10:28 PM
